Name that part..
8th Gear
Name that part..
Hi all,
This is my first post, but I've been lurking for a while. Seems like most of the other questions I have had were already answered about a dozen times so I never needed to post before now.
A while back I hit the pothole to end all potholes (it was filled with water so I didn't know it was there). Anyway, it broke my wheel and I had to get that replaced. Lately, I've been noticing a clunking noise from that wheel (right front) when I go over speed bumps. I took it in and they said it was a broken endlink. I ended up putting some Moog endlinks in, but the noise didn't go away. Today I decided to look around for any obviously broken parts, but couldn't see anything in the suspension. I take a look in the engine bay and sitting on that plastic piece on the bottom I found these guys. Anybody know what they are? Piece of a motor mount?
![](http://i242.photobucket.com/albums/ff279/brownerj/DSCF2216.jpg)
![](http://i242.photobucket.com/albums/ff279/brownerj/DSCF2215.jpg)
'03 ABP YA4-S 6MT
wow, yeah remind me of the top of the strut, your pictures made it seem really huge.. i suggest you look asap..
https://acurazine.com/forums/showthread.php?t=168436
8th Gear
Thanks, I'll go check it out. Assuming I can't do anything with it right now, what should my course of action be? I set up an appointment for monday at the dealership because they won't have a loaner until then. Should I call and stress that I need to come in pronto or is this something I'm better off fixing myself?
8th Gear
I don't mean to second guess you guys, but if I was looking at the part I think you were referring to, there's nothing missing. Here are a couple more pictures to help out.
Both sides looks like this. There doesn't appear to be anything missing, correct?
Here are the parts again with a ruler for reference.
If it helps, I found the parts toward the front of that car. I was able to get to them by unhooking part of the bumper on the bottom and just reaching in there.
![](http://i242.photobucket.com/albums/ff279/brownerj/DSCF2217.jpg)
![](http://i242.photobucket.com/albums/ff279/brownerj/DSCF2219.jpg)
thats a strut rod bushing, washer and bolt. they are known for working themselves loose on hondas. i had a thread on here somewhere about changing them. they will throw your caster of big time seeing as they keep the wheel from moving forward or backward under braking/acceleration.
8th Gear
Ok, I guess I'm a little confused. In the picture above of the strut, isn't that the bolt, bushing and washer safely in place? Or is that something else? Also, this 'bolt' doesn't have threads on it and is hollow. Does it fit around some bolt that's probably floating around in my engine bay?
PS: rp_guy, I'm going to be heading to Edmonton in a few weeks for work. A friend of mine (with a much nicer CLS) is also going.
'03 ABP YA4-S 6MT
https://acurazine.com/forums/showthread.php?t=193382 ??
and edmonton alberta right? what u doing here ?
Yeah thats either your strut bushing, or your radious rod bushing (Strut Rod) The radious rod is the long rod that attaches to your lower control arm and goes forward and connects to your front subframe. If that bushing is missing that would definatly cause a clunking noise
8th Gear
OK, it's too dark to go check it out and I don't have a flash light for some reason. Considering I drive 37miles to work and back every day, is it unsafe to wait until Monday to take it in? Now that I have pieces of my car sitting on my desk while my car is in the driveway, I'm a little worried.
I now drive an accord....
Originally Posted by fuzzy02CLS
They may be old un-needed parts.
Its still strange though that you car is making noises. Perhaps someone who recently worked on the car forgot those parts?
8th Gear
Well, I decided not to risk it and brought it to the dealership. They verified that it was the radius rod bushing and replaced it and tightened everything up. No more noises, so that's good. They claimed they looked over everything, but I'm sure this isn't the last problem I'll have because of that pothole. Anyway, fixed for now. Thank you to everybody for helping - this turned out to be a productive first post.
23109VC
10-09-2017 04:25 PM
