My personal quickest 0-60 time.
Today up in Scottsdale it got cloudy around 6pm. The temp got down to 89 so I figured go do a run. It won't be this cool for a while. I ran my best 0-60 with 1/4 tank of gas and only golf clubs in the trunk. I have a CL-P and I ran 6.82 secs
The temp def. makes a difference as the best I could run before was 7.0-7.2 at 100-105 degrees. So as it gets closer and I get mods I will hopefully bring it further down. Also I ran 0-100 in 16.9 and 60-125 in 25.94
Let me know what you think of the times and that's about it. Anthony
Originally posted by pgatour1:
<STRONG>Today up in Scottsdale it got cloudy around 6pm. The temp got down to 89 so I figured go do a run. It won't be this cool for a while. I ran my best 0-60 with 1/4 tank of gas and only golf clubs in the trunk. I have a CL-P and I ran 6.82 secs
Let me know what you think of the times and that's about it. Anthony</STRONG>
was this at a track or you on your own stop watch....today i tried on my watch and couldn;t break 7's even in SS!!!!
later,
dantes
The 0-60 was Gtech. the 0-100 and 60-125 was on a big stopwatch that you can't screw up on. Like one of those track coaches use. Was the stopwatch you were timing on your wrist or a small button cuase you should be able to break 7's in a CL-S. but that doesn't matter for 0-60 i used Gtech anyhow.
<STRONG>The 0-60 was Gtech. the 0-100 and 60-125 was on a big stopwatch that you can't screw up on. Like one of those track coaches use. Was the stopwatch you were timing on your wrist or a small button cuase you should be able to break 7's in a CL-S. but that doesn't matter for 0-60 i used Gtech anyhow.</STRONG>
Maybe one day you'll see me up there, boy would I love that. I don't play on any of the tours i'm only 17. One day hopefully i'll be playing on one of them if not I want to be the weatherman for one of the tours.
Originally posted by Shaka:
<STRONG>Just to let you know the gtech is off by about .2 (slower than it should be) :p</STRONG>
I doubt I ran 6.62 I would believe 7.02 but I still think that my Gtech is pretty accurate maybe .1 either way.
The gtech's sensor has its reading increased by adding in the sine(tilt angle) * gravitational force and the forward acceleration is cosine(tilt angle)
So,
Let's assume a tilt of 1 degree and a "real" acceleration of .4Gs at take off.
If the GTECH was perfect, it would calculate using the .4G.
However, here is the reading just using the .4 G:
Gtech_accel = real_accel * cos(tilt_angle) + 1G * sin(tilt_angle)
gtech_accel = (.4G * .99985) + (1G * .017452)
gtech_accel = .399940 + .017452
gtech_accel = .417392
The initial reading is about 4 percent higher than it actually is, but the amount of variation will not remain constant and will be dependent on the "tilt" (due to squat) and the acceleration at each 1/1000 of a second.
emailnatec
29
09-28-2018 04:27 PM
ExcelerateRep
10-14-2015 08:20 AM
