windshield sprayer problem
Old Aug 8, 2001 | 10:43 AM
isbworking's Avatar
What, me worry?
From: Carrollton, tx. land of heaving pavement & revenue generating pigs.
I read about this on the TL forum so I thought I'd try it since I never used my windshield spray. It sprays some sort of white residue that sticks to the windshield. The person said it was due to the sprayer lines being broken down by the fluid. He said you have to ask for it for them to replace the lines and fluid. Has anyone else had this problem. I've never seen this on any car before.
Old Aug 8, 2001 | 10:52 AM
russianDude's Avatar
I heard something about smeary windshield fluid people were having problems. maybe you should just drain the fluid, and put a new one?
Old Aug 8, 2001 | 11:06 AM
Scooter's Avatar
'Cooter
the smearing effect was on an early batch of cars due to the alcohol content in the fluid being too high (i think too high, either too high or too low)...since u have a later "born on date," i dunno y u're getting the residue...perhaps there's a break or puncture in a line somewhere...perhaps the wipers need to b changed...perhaps u're getting to the tag ends of your batch of fluid and need to refill...if u still r having problems, do what your friend said, take it in, and have them replace the lines and put in a fresh batch of fluid.
Old Aug 8, 2001 | 11:18 AM
fender4's Avatar
I went to the dealer yesterday for new wiperblades. They replaced them under warranty; said the fluid should be mixed with H2O because it reacts with sun which makes the wiper blades break down and give off a oily subtance. OK by me I got new blades.
Old Aug 8, 2001 | 11:24 AM
louisn's Avatar
That's not the fix. It will come back. Service bulletin on this subject. Use the search feature on this site!!
Old Aug 8, 2001 | 11:29 AM
How do they fix it?? What are the symptomps?
Old Aug 8, 2001 | 11:38 AM
isbworking's Avatar
What, me worry?
It's gotta be more than just the blades because I had a white residue from the spray pattern where it shot out and stuck to the windshield. Probably sucking the acid out of my battery or they're using gelatin for hose material.
Old Aug 8, 2001 | 11:57 AM
BusGradCLS's Avatar
Look... very simple
Take it to the dealer, show them refer to the service bulletin.. they will fix.
I had it done already. They replace the lines, blades and clean the windshield no problem. It is not an earlier car issue, it has occurred randomly but an easy 20 minute fix at the dealer.
Old Aug 8, 2001 | 12:59 PM
fender4's Avatar
I did the search and didn't find any service bulletin ???? please post the number here, thanks
Old Aug 8, 2001 | 04:02 PM
louisn's Avatar
Type, "bulletin and windshield" in search feature.
Old Aug 8, 2001 | 07:55 PM
crrink's Avatar
The mere fact that Acura had to release a bulletin about something like this is ridiculous.
The build quality of other cars CAN'T be this bad.........can it???
Old Aug 8, 2001 | 09:07 PM
KavexTrax's Avatar
Originally posted by fender4:
<STRONG>I went to the dealer yesterday for new wiperblades. They replaced them under warranty; said the fluid should be mixed with H2O because it reacts with sun which makes the wiper blades break down and give off a oily subtance. OK by me I got new blades. </STRONG>
Speaking of oily substance, when i had my car for about 2-3 months, the sunroof's rubber was acting weird when I was washing the car...it would have a gooey oily stuff on it and it was a bit hard to rub off.
But it doesn't ever happen anymore, i dunno why so I never bother with it.
Old Aug 8, 2001 | 09:30 PM
acura_service's Avatar
www.drippinwet.com
there is a bulliten on this see the dealer, this happened to me
SidhuSaaB
May 30, 2020 12:40 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
