my cls check engine light on
+1 for ignition coils...
You could "borrow" a known good coil from someone and replace your's one at a time till you find the bad one...
Check out NSXnext's post here:
https://acurazine.com/forums/showthread.php?t=168147
Doing a search for the trouble code (P1399 or P0300 or whatever it is) will pull up a bunch of threads of people with similiar issues, and what they did to resolve it.
If you're not technically inclined, it's off to the dealer or local H/A expert...
i not sure what is code but i sure
p300
p301
p302
p303
p304
p305
p306
could be egr clogging? my cls had 57k miles on it i don't think i still have warrenty on this car
i reseted computer but englne light come on 2weeks after i reseted it.
p300
p301
p302
p303
p304
p305
p306
Ok the manual says either the ignition coils, or the fuel pressure system.
It would be a little odd for a coil or more then 1 coil to fail at only 57K miles. Check around the coils & make sure all the connections are good.
How does it drive? Is it a probelm when you are at WOT, regular day to day driving?, idleing?
Sundance Gold in
U Need 3 Things For Engine 2 Run: Fuel, Spark And Compression. If U Get Misfire On One Particular Cylinder It May Be: Ignition Coil, Spark Plug Itself, Leaking Compression Thru Spark Plug, Bad Coil Wireing. Injector Going Bad , Poor Quality Fuel ( Will Cause Random Missfire ). Ramdom Missfre Can Be Caused By Almost Everything - Too Much To List.
Simple Things 1st Check Your Plugs.
Originally Posted by akuracls6spd
no everything fine driving just normal gonna check in dealer next wed $105 for just checking expensive...
just change sparkplug to denso ik20 all 6 of them..
still got engine light came back this is nightmare -_-
one of my friend check my car he feel vibrating from engine
i can sense little vibrating from steering wheel hmm
will see i decide not to take this car to dealer.
gonna clean egr port and thottle body this wed will see wut happen
i clean egr and thottle body last week still doesn't fix my engine so
i take it to dealer 3 days ago. they said bad fuel injector causing this problem
so they change all 6 of them.. somehow they didn't charge me nothing anything for it
i thought my car warrenty is expired long time ago. 03 cl type-s 6speed manual 58k on it.
hmm weird but now it's fix very happy with it...
'08 MX5 GT 6spd.
i went to autozone today for check engine light
they said all 6 cylinder got misfiring
wut should i do now? -_-;;
ugh, I hate Autozone.
You're better off putting some made up remedies in a hat and picking one.
Acurazine has helped me so many times in situations like this.
HeloDown
09-08-2015 06:51 PM
