my 3.5L journey begins...
Old 03-28-2006, 01:51 AM
CleanCL's Avatar
time to stir things up on the east coast.
Old 03-28-2006, 02:31 AM
saiko_cl_duck's Avatar
hmmm, interesting. What kinda gains are you looking at?
Old 03-28-2006, 08:53 AM
CleanCL's Avatar
if i had to guess, i would say more than 350 crank hp, but more importantly, i think my torque with be higher than most normal supercharged setups
318whp/289wtq @ 6psi
blk2001tlon19s's Avatar
What pistons are you using? The Cl-S pistons? I have a set of CL-S and a set of MDX pistons if you want as I don't need them for what I'm getting done to my car now.
Good luck with the swap.
Old 03-28-2006, 08:57 AM
CleanCL's Avatar
RL Pistons for my setup.
thanks.
Old 03-28-2006, 09:45 AM
I NEED MONEY!
VeeralS05's Avatar
What parts do you need and how much does the 3.5L conversion usually cost?
Old 03-28-2006, 09:57 AM
JZ0324's Avatar
I cant find the site now, but there is a company that does the 3.5L RL stroker kits for the J32.
The numbers are up there; 350hp and 320 ft-tq I believe. I would love to see some actual dyno numbers on this kit and most importantly, a timeline of proven realibility.
Anybody seen anything in this regard?
What are you planning on running for car managment?
Old 03-28-2006, 11:26 AM
o1s
o1s's Avatar
doesn't a honda dealership in south florida do that? rick case or somthing like that?
Old 03-28-2006, 11:51 AM
JZ0324's Avatar
Yes its them. If you get the parts, a good performance shop can do it.
From our FAQ:
The 3.5L upgrade is done by Rick Case Acura. The really short version is it is a converted 3.5L MDX engine put into a CL.
More specific details:
Roughly 315 hp and 254 ft lbs of torque
0-60 in 5.7 seconds, 1/4 mile in 14.0 sec.
Note runs done at Moroso Motorsports Park in 90 degree and 90% humidity.
Parts:
From MDX: Crank, bearing, pistons, rods, tranny housing 1->2, intake plenum spacer
Comptech Headers, springs, sways
AEM 2.5" CAI
Brushed aluminum interior
Apex VTEC Controller
Head work is done by the Propulsion Laboratory in conjunction with John Brown Racing of S. Florida.
Compression ratio is 10.85:1
Takes 8 work days to produce/convert one powertrain.
Cost: $4999 for 315 HP, and $6999 for a 335 HP Gen II set-up.
One acura-cl.com got the conversion, ran great with it, and had no transmission problems at all
Old 03-28-2006, 11:52 AM
fuzzy02CLS's Avatar
Rick case doesn't do anything performance related anymore. In fact they reject warranties of most modded cars brought in, or just are refused.
Old 03-28-2006, 11:58 AM
CleanCL's Avatar
engine mangement... my stock ECU.
RL cams will be going into the motor. PnP Intake Manifolds, removed VSA, and all the mods you see in my sig.
i haven't seen a dyno with the RL cams, i may be the first n/a with it.
i dynoed at 234 whp with a broken actuator, with 25% drivetrain loss, i'd say that puts me at about 315 crank at the moment. but as i keep saying, i'm thinking torque will be my friend. torque, in a honda motor?
Old 03-28-2006, 12:42 PM
Never had a clean run
rtatsutani's Avatar
thanks.
Nice choice. Did you get the .25 OB or .5?
Old 03-28-2006, 01:16 PM
JZ0324's Avatar
Stock ECU? Really....what will u be using with the full 3.5L build? Can you just use a stock RL ecu?
I dont see your sig. My sig is on too but nada, and some ones I do see.
Old 03-28-2006, 02:19 PM
CleanCL's Avatar
standard pistons. the overbore is essentially if someonething happens to the cylinder walls. i felt it unnecessary to have my block bored, when standard should drop right in.
the CL's ECU will do just fine. click my name and click view profile to view sigs.
Old 03-28-2006, 02:33 PM
JZ0324's Avatar
How many miles on your CL? If its anything over 80k, it might be worth to have the block freshly honed and go with OS pistons. .25 shouldnt be a full bore.
Since your spending a decent amount of money on this full build, I would consider this to be a good preventitve measure. Cost vs possible damage.
The shop thats doing it might cut you a break on the labor for striping the block down, preping, honing, etc.
I have seen wall damage from builds on motors over 100k without a fresh bore or even hone.
I dont believe so, but can you confirm or deny if the CL-S has FRM cylinder walls?
Old 03-28-2006, 02:36 PM
I'm a Vagiterian.
All Mine's Avatar
So you're using the RL pistons, cams, and crank, in the CL-S block/heads?
Old 03-28-2006, 02:53 PM
CleanCL's Avatar
'04 Odyssey Crank
'04 Odyssey Rods
'05 RL Standard Pistons
'05 RL Camshafts
'01 CL-S Block
'01 CL-S Head
...and a few other odds and ends.
Old 03-28-2006, 03:11 PM
I'm a Vagiterian.
All Mine's Avatar
How come you're going with the Odyssey stuff?
Old 03-28-2006, 03:16 PM
Not Asian
phipark's Avatar
Awesome, can't wait to see some progress notes.
Old 03-28-2006, 03:18 PM
CleanCL's Avatar
i got a good deal on the odyssey parts, and their essentially the same exact parts as the MDX except the MDX parts have a higher price tag bc of the acura name to it. IMO, go with oddyssey stuff, its cheaper and it's the same.
also the odyssey and early MDX rods are forged versus new mdx/rl rods which are a slightly different materials.
Old 03-28-2006, 03:21 PM
typeR's Avatar
reliability and dyno numbers with 3 years of abuse
Old 03-28-2006, 03:26 PM
CleanCL's Avatar
steve, thanks for the help. i can't wait to see what the cams will do. i plan to keep everyone posted as to any problems that arise.
the crank is going to the machine shop, hopefully it's good to go. and the RL piston rings are on backorder, doh. gotta find 2 ringsets.
Old 03-28-2006, 06:07 PM
ThinJim's Avatar
Remember though, The RL block is equipped with oil squirters to keep the piston cooler which aids in reducing detonation, That's one reason it works so well in the RL. Good luck with that build!
Old 03-28-2006, 07:05 PM
Yumcha's Avatar
Received 22,949 Likes on 14,062 Posts
Awesome! G'luck with the swap...keep us updated!
Old 03-28-2006, 07:37 PM
rtatsutani's Avatar
I was worried about that too but all seems great.
Damn, RL pistons were on back order when i tried to get them too. The company I ordered them from ended up buying them off another warehouse since the wait was so long.
Old 03-28-2006, 07:42 PM
rtatsutani's Avatar
PS, you getting the Riken piston rings right? Those are less than 1/3 the price of the regular ones.
Old 03-28-2006, 08:02 PM
CleanCL's Avatar
i ordered from oemacuraparts.com, lance has been very helpful.
about the oil squirters, i honestly dont think its going to be a major issue for an n/a build. but i may talk to the shop about having light ports done to the oil pathways.
Old 03-28-2006, 08:45 PM
Lead Footed
RUF87's Avatar
Ruf
Old 03-29-2006, 12:08 AM
ghost_masterCL's Avatar
nice job. you already sent in your tranny?
Old 03-29-2006, 08:16 AM
CleanCL's Avatar
the tranny is a whole nother issue...
Old 03-30-2006, 12:36 AM
av6ent's Avatar
Nice. Did you get crank/rods from 02AV6?
Old 03-30-2006, 08:40 AM
CleanCL's Avatar
yes, i did.
Old 03-30-2006, 11:14 AM
East Coast Boost.!
Titand19's Avatar
good shit, where on LI are you , I'd like to see this and might take it into consideration for the future
Old 03-30-2006, 06:19 PM
CleanCL's Avatar
i'm north shore nassua. but build is being done in queens. hit me up some time, we can check out the cars.
i'm sure most of you know this, but maybe some don't. this build will bump compression, i'm not 100% sure, but it will be about 11:1. this is a bit high, but i still think you could do a light boost on it. for me, i am going strictly n/a, so this is perfect. thanks to NY and standard 93 octane =]
Old 03-30-2006, 06:53 PM
mrsteve's Avatar
You'll be fine with 11:1 compression.
Old 03-30-2006, 08:34 PM
typeR's Avatar
the spoon kits bump compression to 12.2:1
Old 03-30-2006, 08:45 PM
mrsteve's Avatar
Spoon makes parts for the J-Series?
Old 03-30-2006, 09:05 PM
typeR's Avatar
no im just sayin...but whats the stroke on a NSX?
Old 03-30-2006, 09:15 PM
CleanCL's Avatar
78 mm / 3.07 in
Old 04-04-2006, 11:29 PM
CleanCL's Avatar
minor update....
UR Underdrive pulley set, all new thermoblocks, and mugen stuff will be put on the engine. I feel this will be better for long run. This means I will have UR Pulleys/Thermoblocks for sale sometime soon.
Quick Reply: my 3.5L journey begins...
