Mugen t-stat? (scalbert)
I was reading in the archives about people who live in cold climates that this might give problems to the car not heating up properly. I live in chicago where it gets down to the negatives in winter and 90's in the summer. Unfortunately I drive my car year round so can I get both and not have a problem or should I just get the fan switch to help with some cooling in the summertime. Because I definitly don't want to loose heat in the winter or does it just take longer to heat up?
I can't really comment on the heat issue as I don't see the lower temps you do. But I beleive others in northern states ran it without issue not noticing any decreased cabin heating ability.
It isn't really the max temperature as it is the time to get up to a comfortable temperature. With air that is about slightly cooler will slow the heating of the cabin.
I doubt that the amount of time is significant enough to notice though. ModAddict said that he didn't have a problem and he is in Michigan.
I installed the Mugen themostat, fan switch, and radiator cap when I lived in Atlanta about 18 months ago. I have lived in the Chicago area for the past two winters. No problems with the heat in the winter.
I would say go for it.....
Spectacular Aroma About
I just installed the Mugen T-Stat and fan switch last night. The engine actualy seems to warm up more quickly but stabilizes at a lower temp which seems to back up their claims. This is what it says about it on King Motorsports site:
"This thermostat has the operating temperature set lower than normal. It prevents engine power loss by minimizing rapid water-temperature rises under harsh conditions such as during circuit driving. The use of a flow-control-type valve prevents hunting, thereby achieving rapid stabilization of the water temperature (the engine warms up within a short period). Operating temperature: 68?C (STD.: 76~80?C) Full-throttle acceleration temperature: 81?C (STD.: 90?C)"
BTW Thanks Scalbert. The part #s you listed fit perfectly. Nice easy mod. I lost some coolant though and added a bottle of Water Wetter and quite a bit of water. Do you guys think I should flush it before winter to get back to a 50/50 mix? I should be around 70/30 or better now.
Thanks guy's. I new the cabin heat would be the same. I just read that the initial heat up to be longer, but didn't know if it was significally longer or not. I have remote start anyways so I'll just start it sooner than usual.
Originally Posted by Dimcorner
Wouldn't drilling a small hole on the thermostat work almost the same way?
http://www.acura-cl.com/forums/showthread.php?t=85921
Iakonafuji
09-21-2015 02:39 PM
