Mugen T-Stat Fits
Old Nov 9, 2002 | 09:47 AM
scalbert's Avatar
Mugen T-Stat Fits
Yep Eric, it only took one pitch...
The only Mugen T-Stat sold by King Motorsports does fit our car. I did swap the rubber seal from the stock unit to the new one because they were slightly different. But other than that it was a perfect match.
It did warm up normally but kept the average coolant temp at about 180 F with the new Mugen switch. So the previousl;y mentioned part numbers are correct.
Old Nov 9, 2002 | 10:00 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
how much you paid..? do you need to do any other stuff... like water wetter addition?
Old Nov 9, 2002 | 10:09 AM
scalbert's Avatar
This T-Stat must be made of Titanium as it is the most expensive stat I have purchased, $69.00...
I also have the B-Series fan switch which is also required and it ran $45. I did get the rad cap and added Water Wetter along with running only about 30% anti-freeze (not a problem here).
Old Nov 9, 2002 | 08:45 PM
peiqinglong's Avatar
I recall you mention something about drilling, is this still true?
Old Nov 9, 2002 | 09:01 PM
typeR's Avatar
he drilled the stock which dint work out...the mugen is a straight bolt in and go
Old Nov 9, 2002 | 11:42 PM
EricL's Avatar
Re: Mugen T-Stat Fits
It did warm up normally but kept the average coolant temp at about 180 F with the new Mugen switch. So the previously mentioned part numbers are correct.
Home run!
So, the Integra and/or Civic ("B" motor) page part #s you supplied are good to go ... hey?
How about a "Cool-down install story from you?" It can be put in the FAQ/Archives!
(So much for the two thermostats for the Accord story…)
Old Nov 10, 2002 | 04:24 AM
RDX's Avatar
RDX
so civic/teg Thermostats fits the J-Series Engine?
Just the switch of rubber? do u have a pic of it?
thnx
Old Nov 10, 2002 | 07:59 AM
dj_3000's Avatar
Steve, how hard was it to remove the thermostat housing?
I know that it is only two bolts but looks like one is kind of hard to get to. Any problem removing without air tools?
Old Nov 10, 2002 | 03:00 PM
scalbert's Avatar
Re: Re: Mugen T-Stat Fits
Yep, those are the correct one's...
Old Nov 10, 2002 | 03:10 PM
scalbert's Avatar
Ok, here is the quick write-up with pics. Instead of draining coolant off first I did it the simple way; I just let it pour out and cleaned up afterwards. Actually I did it in the driveway and put a large pan underneath which caught about 75% of the about two quarts which was lost. The rest poured onto the driveway and I immediately sprayed it down. I also spray the trans case where the fluid ran down to clean it up.
For the removal/install all you need is a 1/4 inch ratchet and short extension along with a 10 mm socket, I used a deep socket. Just remove the two bolts, one at the top left and on at the bottom right. Once removed the housing will fall away, along with fluid draining out, exposing the top of the stat. Just pull on the top of the stat and it will slide out and then fluid will pour out. Once out just swap the rubber ring to the Mugen stat and reverse the order.
Stock T-Stat that I drilled:
Front view showing the top bolt:
Rear view showing the lower bolt and the Mugen fan switch:
Old Nov 10, 2002 | 07:12 PM
dj_3000's Avatar
Thanks for the pictures.
Good luck to you and your wife next week with the IVF.
Old Nov 13, 2002 | 10:18 AM
Is there any disadvantage to running the mugen t-stat? Like does it put more load on your engine turning the fan on earlier? Any dangers?
Old Nov 13, 2002 | 10:27 AM
scalbert's Avatar
There might be slightly higher emissions output, barely measureable though. Also slightly decreased cabin heating since the coolant is at a lower temp, less heat to transfer into the car.
That is about it.
Old Nov 13, 2002 | 10:50 AM
Juker008's Avatar
TRELOS
That is about it.
OK but what if the fans were left off?
Juker008
Old Nov 13, 2002 | 11:05 AM
scalbert's Avatar
Which fans, the cliamte control blower or the radiator cooling fans?? I guess I didn't fully understand the question.
Old Nov 13, 2002 | 12:34 PM
Juker008's Avatar
TRELOS
The radiatior cooling fans. Those are the ones that I assume u changed the switch on, correct?
Juker008
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
vpasla1
Sep 17, 2016 07:24 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
ROWDY621
Sep 30, 2015 03:20 PM
Bielikb96
Sep 28, 2015 10:45 AM
