Moving battery to the rear?
Old Jan 28, 2002 | 10:39 PM
NOVAwhiteTypeS's Avatar
I know it'll probably help distribute the weight but is it really worth it?
Eric what do u think?
Old Jan 28, 2002 | 10:55 PM
bioyuki's Avatar
Re: Moving battery to the rear?
LOL, the only car I know with a battery in the rightside of the trunk is the M3/M5. Thats taking it to the extremes.
Old Jan 28, 2002 | 11:03 PM
Re: Re: Moving battery to the rear?
really? hmm my friend w/ his old 325 must have moved it then.
also he volvo coupe in the picture w/ me had also moved his.
Old Jan 29, 2002 | 01:45 AM
SinnedTL's Avatar
Ain't No Other...
hmm actually alot of european cars have their batteries as a safetly system in the trunk...I know my C-Class Mercedez had it in the trunk, other class mercedez should also have it in the back, as well as BMW's and Volvos...m5/m3 is not the only cars with it in the back, alot of euros are made that way...
Old Jan 29, 2002 | 01:58 AM
thnx. I knew I wasn't nuts!:P
Old Jan 29, 2002 | 02:17 AM
Iridium130's Avatar
w.t.f., mate?
my friends 540 has it in the back...I can only assume the other 3 and 5 series have it in the back.
I think the 7 series has it in the front though....
Old Jan 29, 2002 | 07:30 AM
fbazakos's Avatar
on bin laden
my dad's 740iL has the battery in the rear.
Old Jan 29, 2002 | 08:25 AM
someguy's Avatar
You are right. BMWs have them in the trunk.
With as nose hevy as the CL is, I doubt it will make a noticable difference unless you do a major front end lightening.
Old Jan 29, 2002 | 08:28 AM
Dom418's Avatar
I LOVE MY CAR
How hard is that to move to the Back ???
Old Jan 29, 2002 | 02:15 PM
ZodiakTL's Avatar
Acura TL-S
some bmw's have them in the trunk, i know for a fact that the 3 series 99-01 have them under the rear passenger seat, in the 4-door version at least, but i would assume the same for coupe... i dont know how much diff 30-40lbs would make... but it does help them get that much closer to the perfect 50/50 weight distro... and actually, since u take away 30 from the front and put 30 in the rear, it seems equivalent to putting 60lbs in the back... so actually it might be noticeable..
Old Jan 29, 2002 | 02:49 PM
Fabvsix's Avatar
Cajun Gumbo Man
My old boss' 1978 911 Porche, was under the drivers seat or rear seat and was super small and VERY expensive ! I remember, cause she would bitch about the cost of it !
Old Jan 29, 2002 | 03:19 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Go to summit and get a battery relocation kit...if you ever plan on taking it to the track..make sure it is the box that is NHRA-legal.
www.summitracing.com
Old Jan 29, 2002 | 03:53 PM
someguy's Avatar
You are wrong, the E46 has it in the trunk. I think that all late-model BMWs do as well.
I put this together to help any CL owners that wanted to try it.
This particular car is a 2000 328Ci
This is a jump start terminal. You will need one in case the battery is dead.
Something to cover up the battery
The battery itself clamped in tight. It shouln't have any play
And, of course, cable running to the starter
Old Jan 29, 2002 | 05:26 PM
Volvokindaguy's Avatar
Re: Re: Re: Moving battery to the rear?
Me? :p
Hehehe...only reason I moved it was b/c of the intake.
Old Jan 29, 2002 | 06:34 PM
silverstarr's Avatar
Battery in Trunk
Yeah, even the Lincoln LS has the battery in the trunk to help with weight distribution.
Old Jan 29, 2002 | 06:40 PM
Type S's Avatar
Powered By HONDA
it is going to be a big job for cls or tls.and how are u going to wire them from front end to rear end?big job
Old Jan 30, 2002 | 04:31 AM
KavexTrax's Avatar
Wouldn't it also be a good idea for security,
to have the battery in the trunk?
So thieves can't disable it?
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
