More Car Problems
Lives On BOOST
More Car Problems
I was coming back from seeing my old man tonight in walnut creek and as I got onto an offramp in san francisco my car died. I was downshifting and when I noticed that as I tried to give it more gas the car wasn't moving. I didn't over rev or anything, the car seemed to shut off. My buddy came to try to jump the car but it didn't work. I was thinking it could be the alternator b/c the car turns over like it's about to start and then fails. I'll know the details by tomorow
Its not the alternator because if it were that then when your buddy came to jump you it would have worked. The alternator recharges the battery but when it doesn't work an alternate source can still get your car started. It could be the starter or something electrical. I never had my Acura cutoff on me like that but I had a VW do that to me and it was an electrical problem.
Trolling Canuckistan
Do you know if you are getting fuel to the engine? As others have mentioned, it's most likely not the altenator, if it was a jump start would have worked as a temporary fix.
yeah, i think the car would've ran for a bit if your friend's car was connected. fuel to the engine is the next check for you imo. spark plugs? maybe one blew up or something.
Lives On BOOST
Originally Posted by CL FWD SPEED
do you still have any CEL misfiring codes? if I could recall...if you do, have them check that out too while your at it.
Originally Posted by krisdlm
the shop told me yesterday that the timing belt broke! They're going to put on a new one and do a compression test tomm. I'll have my fingers crossed...
Originally Posted by Allout
If the timing belt broke, I would expect damage to valves & pistons. Good luck with it.
I think our motors are non clearance type motors. If the timing belt broke the valves are surely bent but the pistons could be fine if a valve top did not break off. Someone correct me if I am wrong.
Lives On BOOST
Didn't the shop who installed your motor also replace the timing belt at the same time? If so, it shouldn't have broken the belt.
