More Boost
Old Sep 8, 2004 | 10:24 PM
allmotor_2000's Avatar
More Boost
Well, I installed the boost regulator and tried it out. I set it to 7.5psi with the exhaust open (hit about 7psi with it closed) - This is a healthy 1.0psi-1.5psi increase. Anyways, 2nd feels awesome, but it starts misfiring in 3rd and 4th. I don't have time to tune it today, but its probably one of the following:
(1) Plug gaps are too large
(2) Gas is bad (91-octane)
(3) Fuel pump is doing bad things? (I see 90psi fuel pressure now... I need to change the spring on the comptech FPR)
(3) Something else bad...?!?
Anyways - I probably won't play around with it for a while as I don't have time.
Old Sep 8, 2004 | 10:34 PM
darrinb's Avatar
///M POWER
i'd drop in some 100 octane to see if that clears everything up
Old Sep 8, 2004 | 11:02 PM
pimpscls's Avatar
THE SILVER BULLET
^ werd, Speaking of that kinda octane, where do you get that shit in cali?
Old Sep 8, 2004 | 11:13 PM
Mike's Avatar
http://www.osbornauto.com/racing/100locations.htm
Old Sep 8, 2004 | 11:15 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
Whoooooooooooa, that must be awesome! Can't wait to hear what it's like in 3rd and above when it's running right!
Old Sep 8, 2004 | 11:32 PM
I get it delivered to my house... do you want some?
Old Sep 8, 2004 | 11:43 PM
andyjl's Avatar
how much is some of that down in Southern California?
Old Sep 8, 2004 | 11:58 PM
CleanCL's Avatar
what gap are the plugs at? how are you monitoring fuel pressure? i know i had a hard time moniroting fuel pressure on one of my turboed cars because we tried putting a cheap gauge right into the fuel line in the engine bay that goes to the rail, its good for awhile but breaks after a little (no leakage, just wrong readings)
i dont know much about the kit, but obviously you have a FPR, but do they have you replace the fuel pump? what about injectors or fuel rail? sorry if i sound stupid, but i do have a lot of experience with turbos, just not your particular setup.
p.s. i would try to get that running right on 91
Old Sep 9, 2004 | 01:24 AM
I haven't checked my plugs. I have an electrical fuel pressure guage (works great). I replaced my pump as well. Injectors are stock... I have a secondary injector as well (750cc).
Old Sep 9, 2004 | 02:19 AM
BC2G's Avatar
Registered Big Dog
wow extra boost thats awesome
..... good luck w/ the fix
Old Sep 9, 2004 | 03:25 AM
JHEIII850Turbo's Avatar
wow man, that car just keeps getting more and more impressive. Pretty much my favorite thing going on here on Acura-cl.com Congratulations on getting her to like higher boost levels.
Definitely check spark plug gap, I've run into that issue wayyyyy too many times, IIRC cl's are a PITA to change plugs on, though... either way, best of luck.
Old Sep 9, 2004 | 11:44 AM
CleanCL's Avatar
if your seeing your fuel pressure to be 90 psi on boost thats not too bad, you may need to drop the gap but not a lot considering your only adding about 1-1.5 psi, maybe you just need to retune for the extra boost. good luck.
Old Sep 9, 2004 | 12:12 PM
EricL's Avatar
5 1/2 to 6 buck a gallon for the 100...
As of today, at the Brentwood 76 station, it was 5.93/gallon.
Canyon Service & Detail (and independent) has the 100-octane for around $5.50/gallon
"Said to be the oldest working gas station in Los Angeles county, Canyon Service & Detail is a surprise, a tiny jewel on Entrada in Santa Monica Canyon, a wholly cool fragment from another, simpler era..."
If you need a couple of gallons, well....
Old Sep 9, 2004 | 12:25 PM
rezurex's Avatar
drop em like its hot
can't u just run offa toluene?
Old Sep 9, 2004 | 12:40 PM
EricL's Avatar
You can mix-up some "rocket fuel" by adding toluene or xylene ... nasty stuff
LINK on using "STUFF" to up the octane:
http://www.vtr.org/maintain/gasoline-octane.html
Old Sep 9, 2004 | 12:42 PM
evilone's Avatar
COME AT ME BRO!
is it a daily driver all?? if so your gunna drive around with it misfireing uggh thats bad. i know you will solve the prob though
Old Sep 9, 2004 | 02:15 PM
I drive it everyday...
Old Sep 9, 2004 | 03:18 PM
ThinJim's Avatar
hmmm. misfire could be a number of things.
Do you have an EGT gauge? This can speak volumes to whats happening inside that motor. With a turbo, i'd say that an EGT gauge would be one of the most important monitoring devices you should have.
No expert, but sounds a little lean to me.
Old Sep 9, 2004 | 04:30 PM
A/F's are reading 10.5, so I don't think its lean - I suspect I know the problem, will check it tonight.
Old Sep 9, 2004 | 06:01 PM
Meth's Avatar
*waiting for results anxiously*
Old Sep 9, 2004 | 08:40 PM
Okay... problem fixed: My stupidity actually
I had typed in '4' for the timing retard instead of '-4'... so it was trying to advance timing and we all
know that the E-manage cannot advance timing!!
In any case I ruined the regulator as well by mounting it in the engine compartment... it doesn't like heat!!
Old Sep 9, 2004 | 08:43 PM
mrsteve's Avatar
Sweet
Old Sep 9, 2004 | 10:10 PM
darrinb's Avatar
///M POWER
how does it drive now ram??
Old Sep 9, 2004 | 10:15 PM
stupid computers :p
Old Sep 9, 2004 | 10:46 PM
av6ent's Avatar
Holy moly!
Old Sep 10, 2004 | 08:40 AM
scalbert's Avatar
:cough: user error :cough:
Glad to see you caught that. Now let us know how it feels.
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
Sep 17, 2015 08:57 PM
Sep 14, 2015 10:48 AM
