Misfires... any ideas?
I don't want to go through an arduous debug on this, so please lend any ideas from experience.
I get misfires (all cylinders) when I start up the car in the morning. At first I thought it was a batch of bad gas, but after three tanks, it is still persistent. I swapped out all the plugs for some IK20's and it still does it when the engine is cold. If I clear the code after she warms up, it doesn't come up. I noticed some crud on one of the plugs (front middle cylinder), so I am unsure if that coil-pack has started acting up. I have also heard about catalytic convertor problems results in these symptoms. Can one coil-pack cause mis-fired on all cylinders? I don't think so, but then again one never knows!?
Just based on what I've read here I think you are in the right direction with the coil packs and/or the cat. I remember reading that a faulty coil pack caused multiple misfires and and very rough idle in one car. Also, I believe "typer" had a bad cat which caused misfires.
coil pack and cat. i think you would throw a code for your cat if that was it. i reaplced all 6 of my coil packs so i have my 6 stock ones sitting here. i haven't figured out how to test them but if you can tell me a way, i can send you one of my good packs so you can troubleshoot the packs.
Nope, I changed the plugs, reset the ECU and checked for opens/shorts on the
harness. No change - the HELMs just asks to replace stuff and I am not going to just do that.
I think I know the problem. Front middle cylinder is gone... plug is already fouled and there
is oil in there - a lot of blow-by. Probably need a new block.
I have been having a problem with my '03 CL-S 6MT and I was wondering what exactly a misfire would feel like? Reason I ask is b/c I have been thinking this might be something related to the exhaust. The problems I am experiencing is first, everyday when I turn on the car and start driving to work my engine will all of a sudden pull back for a second as the engine reaches its normal operating temp, almost like I let my foot off the gas and put it back on. It does it pretty consistently and it will do it in any gear. The next problem I have noticed was during rush hour the other day but have experienced it before. As I accelerate and rev up my engine it sounds a lot deeper, but not in a good way. Almost like it is hollow or not all there. It is a little rougher too, it does this in neutral and rev the engine as well. My first reaction was something was caught in the exhaust, but I don't know. I also noticed it will do it more if I don't give it enough gas when I start in 1st and it stutters a little. Any suggestions?
The cause?.. I'm only speculating, but my first guess would be detonation from the boosting. You'd be surprised at how much this thing detonates unless you have a knock detector that lights up when it senses knock. On mine, I didn't think I was det. , but after putting on the knock detector, it lite up like a christmas tree, it wasnt' sever, but it was always there till I pulled more timing and started running av gas more in the mix of fuel I was using. It doesn't have to be severe detonation to do damage. An accumulation of lite det adds up to a heavy hammer pounding the pistons over time.
Hope you can work this out. Keep us posted.
I'll do a compression test and a leakdown - but I can tell by looking at brand new plugs after 1 week
I could get away with just replacing one piston but if I am going through the trouble, its easier to just replace the block with a new (or rebuilt) assembly. Let me ponder it for a while. I have a few months before I start school and the car needs to run properly for the next three years.
On the detonation - you are probably correct. I went by audible detonation and signs off the plug and even a slight amount accumulated over 20K hard miles probably did me in. I mostly used 91-octane as well... at 6psi.
Will keep you folks posted - I was considering selling it, but can't do so given the condition.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
The only other alternative is (and I am contemplating this but not sure if I want to do it) to build a high output 3.7L NA and try to push 350+ whp naturally aspirated. It can be done but might just take too long
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
The only other alternative is (and I am contemplating this but not sure if I want to do it) to build a high output 3.7L NA and try to push 350+ whp naturally aspirated. It can be done but might just take too long ![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
hehehe I suppose that too is possible. Already have plans lined up for the valvetrain? Would you use the '05 RL cams?
A brand new complete assembled block is about $1,400 from online Acura parts dealers.
i was thinking about an overbore and resleeving, but i decided against it. i don't want to touch an already perfect block. albeit, 3.7 would be nice. you could probably make up the extra .2 with minimal work, i'm sure the block could take it.
if you have the ability, do it. i just didn't want to be bothered with custom rods/pistons, among other things. i will have spare CL-S rods/pistons shortly, i'd be more than happy to send you a set.
Blown is Best
Now your talking. It would be a rather simple undertaking to do and using the RL cams and some head work, 350 could be possible, I'd think closer to 320 though.
Originally Posted by Allout
Sorry to hear that. I was hoping you had a plugged CAT or something easy. ![Frown](https://acurazine.com/forums/images/smilies/frown.gif)
I see - might be a cheap thing to try before doing anything else. One concern I have with the entire cylinder #2 scenario is that why are there always misfires on all cylinders (including random misfires). If its something global causing this, then the catalytic makes more sense.
Originally Posted by CleanCL
just pickup a magnaflow universal with center o2 and have them cut ur old cat and weld the enw one. thats what i did, didnt cost more than 150 to do the whole thing.
http://www.car-sound.com/catalog/universal/540.aspx
part#: 54055.
hottexhaust has it for $81
http://www.hottexhaust.com/search_re...&btnSearch.y=0
should not cost more than 50 to have it welded in at any muffler shop.
part#: 54055.
Thanks... I did more debugging:
1. Put my OBD2 tool and saw that the short-term fuel trim and long term fuel trim were at -10% and -7.2%.
2. Saw that the O2 (secondary) was also correcting about 10% just as the primary O2.
Now, there is a rich condition, so my thoughts went back to the Front middle cylinder. While the engine was running, I removed each connector to the coils one by one and listened to the engine change is 'pulse'. All cylinders made a pretty consistent *pud* *pud* except for the front-middle where the change was hardly noticeable. To eliminate the coil-pack, I swapped it with another one and the result was the same. This tells me this cylinder has low compression - confirmed; but low enough to cause misfires?
Now, why ALL cylinders show misfires is still a mystery. It is possible that the cat is still somehow in bad shape, but I can't think why...? The misfire is not detected like the knock sensor... it is specific to a cylinder - is it possible the ECU goes mad when it gets a lot of misfires and just lights up all cylinders?
When your cat went bad, was something actually broken inside and rattling around? How was the cat found to be bad?
reason your cat may be damaged, if your running rich, there is probably extra gas shooting into your exhaust and being burned up in your cat.
1 cylinder misfiring can change firing pattern on all of them. do a leak down on that cylinder. i cant imagine just 1 piston being messed up. in fact, i have heard of very few people blowing this motor.
