Manual Gear Top Speed...
What is the top speed for each gear? can someone find out? My car hasn't broken in yet, so I really don't want to push the car to redline on every single gear. Thank you.
Ever noticed your RPM gauge ? Common sense tells you ! When your engine sounds like it going to blow, time to shift.....its called red line rpm's........!
I don't have a 6 speed CLS, but the manual for my 6-speed Z lists the maximum speed in each gear. Maybe check your manual?
I would like to know also. It's good info, so you know what speed is safe to downshift. Like when passing someone on the HW. I'm doing 90mph in 6th. Can I downshift to 3rd or is that speed too fast? I need 4th then? Stuff like that.
Originally posted by I am RobG
1st is about 27, 2nd is about 56-58ish, 3rd is about 80ish, 4th is around 105 5th is around 130 and 6th is at the 149(governed)
Robg is close, 1st-32 2nd-64 3rd-89 4th-120 5th-142 6th-?....I know this car is capable of speeds over the 149 governing, but its a matter of getting that thing removed...also like someone else said, if you dont want to hurt your baby, shift at like 4000RPM's, then you won't even get into VTEC
I was hoving around 147 in 5th gear one time... and I was just about to shift to 6th and it was still pulling hard (turbocharged, of course!)... but my exit came up rather quickly and I had to slow down... I think 160+ is possible
Originally posted by spdy0001
Explain to me exactly how you are going to hurt the engine by taking the car into V-TEC, after all that is what makes the HONDA/ACURA cars so great.
Acura suggests breaking in the car below 4K RPM for the first 600 miles.
I think he was just trying to say that you'll 'baby' your engine if you keep the RPMs low.
I've always wondered if there is a MTBF rating for engines and if this varies with engine speed. I wonder how long you can rev the car at redline, or just below, and how long it can hold there before some failure event occurs.
mugen_kid
Nov 13, 2015 10:38 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
