Making work butterfly on IM
Old Feb 4, 2005 | 12:57 PM
av6ent's Avatar
Someone asked over v6p who planning to install CLS heads on AV6 block which is fine as we know, BUT if individual is going to use CLS IM (intake manifold) isnt there a butterfly that switches from short to long runners depending on the rpm. I heard that making the butterfly work was alot of trouble, and wasnt accurately switching.
Old Feb 4, 2005 | 01:12 PM
av6ent's Avatar
Ok, butterfly controlled by the CLS ECU, so since they using AV6 ECU then is it possible to disable the butterfly to make the IM work fine?
Old Feb 4, 2005 | 01:46 PM
NSXNEXT's Avatar
I thought I heard someone was working on a RPM switch to open the butterfly valve. Anybody remember that?
Old Feb 4, 2005 | 02:31 PM
scalbert's Avatar
First, dual manifold on the J32A2 does not have variable length runners; it is a variable volume ssystem. The runners lengths are always the same.
And yes, using the IMRC controller and an RPM switch, you could control the opening of the butterfly valve seperate from the ECU.
Old Feb 4, 2005 | 02:34 PM
typeR's Avatar
steve i pm'd you...
Old Feb 4, 2005 | 02:42 PM
scalbert's Avatar
Originally Posted by typeR
steve i pm'd you...
Yea, got it but I'm actually watching a presentation this afternoon and passing time by screwing around on the forum.
Old Feb 4, 2005 | 03:57 PM
av6ent's Avatar
Gracias! And by just disabling it will it hurt performance?
Old Feb 4, 2005 | 04:06 PM
av6ent's Avatar
I mean for NA disabling butterfly valve I think it will hurt the performance and not much or nothing on FI, right?
Old Feb 4, 2005 | 04:56 PM
scalbert's Avatar
Yes, it will significantly hurt torque output in the mid to upper revs on an NA engine.
Old Feb 4, 2005 | 06:45 PM
NSXNEXT's Avatar
Kinda like breathing with only 1 lung. If you're sitting still you can do ok with one, but once you start moving (high revs) you'll get winded.
Hey pretty good analogy huh?
Old Feb 4, 2005 | 07:12 PM
power3dfx's Avatar
Parting out 02 Type S :(
Pretty good,but can you adapt this analogy to why SC cars dont really need the other lung? lol
Old Feb 4, 2005 | 07:15 PM
scalbert's Avatar
Yes, if you hooked up an air compressor hose to your mouth you can keep that one lung over-filled.
Old Feb 4, 2005 | 07:16 PM
NSXNEXT's Avatar
Stick your head out the window going 70 and tell me if you'd need both lungs.
NSXNEXT's Avatar
That was the other one I was going for, only I said Shop-Vac turned to blow air.
Old Feb 4, 2005 | 07:19 PM
power3dfx's Avatar
For the Sc analogy: You are still breathing through 1 lung, but once you start moving you have an oxygen mask that supplies more oxygen per every molecule you breath in, therefore you dont need the extra lung capacity to run right at higher revs!
If an AV6 is going through the trouble of getting all these parts from a type s, then i am assuming it should be boosted anyways and not need the actuator anyways.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
