Maintenance light flash
Old Feb 12, 2011 | 09:09 AM
xtremecro's Avatar
Maintenxeblight flashes when car starts 3 times and goes off. Same on DII no other lights flash 2003 cl auto
Old Feb 12, 2011 | 09:34 AM
gnuts's Avatar
3.5 psi
means your tranny is on the way out. Just kidding. It's for oil changes. You need to reset it. You can search but i think it goes like this: hold the two buttons beside the gauges down and insert the key and put it to the last position before the car turns on. Hold it for like 10 seconds and it'll beep, and it's now reset.
Old Feb 12, 2011 | 09:48 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
x2
Old Feb 12, 2011 | 10:36 AM
xtremecro's Avatar
Thanks For scaring me! Well I got 800 miles left till the change! Thanks guys
Old Feb 12, 2011 | 10:52 AM
the maintenance light goes through sequences of blinking more and more and more hen u start the car and eventually stays on to let u know u've reached 7500miles i believe.
meanwhile i change my oil every 5000kms which is less than 3400miles
Old Feb 12, 2011 | 11:53 AM
TheWeez's Avatar
I Wanna Beer
Per the owners manual:
For the first 6000 miles after the Maintenance Required Indicator is reset, it will come on for two seconds when you turn the ignition switch ON (II).
Between 6000 miles and 7500 miles this indicator will light for two seconds when you first turn the ignition switch ON (II), and then flash for ten seconds.
If you exceed 7500 miles without having the scheduled maintenance performed, this indicator will remain on as a constant reminder.
Old Feb 13, 2011 | 12:11 AM
ivan06106's Avatar
my car started doing that today so i take it to my local auto part to get it diagnose...i did my oil change bout a month ago i hasnt been 1000 miles
Old Feb 13, 2011 | 09:55 AM
gnuts's Avatar
3.5 psi
it's probably flashing because the last mechanic doing your oil change didn't reset it. I never use it. Just reset it when it pops up.
Old Feb 13, 2011 | 10:33 AM
aznboi2424's Avatar
Old Feb 13, 2011 | 10:35 AM
yea totally^^
the fact it's 7500miles leads me to believe acura wants that oil to gum up and destroy the engine prematurely. LOL
oops did i say that.. :-)
Old Feb 13, 2011 | 11:39 AM
ivan06106's Avatar
how do i reset it, i do my own oil change
Old Feb 13, 2011 | 11:43 AM
gnuts's Avatar
3.5 psi
did you read this thread?? it's written above.
Old Feb 13, 2011 | 12:03 PM
WOW... talk about OBLIVIOUS lol.
in order for a forum to be work, you must read young grasshopper
Old Feb 13, 2011 | 01:57 PM
civicdrivr's Avatar
This question comes up every now and then, Im surprised this topic hasnt been stickied.
Then again, its in the owners manual. If they didnt look there Im sure they wouldnt look at the stickies or FAQ section either.
Old Feb 13, 2011 | 02:55 PM
TheWeez's Avatar
I Wanna Beer
Pretty sure it's addressed in the FAQ section.
Old Feb 13, 2011 | 05:50 PM
typeR's Avatar
Originally Posted by CL-S progression 01
i think someone doesn't like me in the mods section
its not just somebody its everybody and its not just the mod section .... j/k seriously civic ... u should change that ... as nice as it is ... im at work ... and if the wrong person sees it could be a problem
Old Feb 15, 2011 | 02:22 AM
OperationDarkie's Avatar
Ultra Negro
if im not mistaken you also throw a check engine light at 150k miles which says dealer maintenance, I had to reset that one.
Old Feb 15, 2011 | 06:12 PM
aznboi2424's Avatar
Why would it throw it at 150k?
Its unrelated.
Old Feb 15, 2011 | 07:02 PM
u mean the maintenance light code right?? a check engine light is the other one?
if it went at 150k maybe someone reset it prior and it fell on that number.
but a CEL at 150k sounds unlikely to be the way acura designed the car. IMHO
Old Feb 16, 2011 | 04:35 PM
Rapture's Avatar
Ugh, it's annoying as hell when the dealer doesn't reset the maintenance reminder It just seems like since it's the easiest part of a service, they probably wouldn't forget to do it.
Old Feb 16, 2011 | 06:45 PM
Ultra Negro
No its actually a check engine light, it was weird all it said was dealer maintenance when I used the tool to reset it.
Old Feb 16, 2011 | 10:31 PM
cu0ngsayz's Avatar
just reset mine... hold the reset and select button then turn key to the on position.
Old Feb 18, 2011 | 07:22 PM
RoccoRock's Avatar
^keep both buttons pressed in until the light goes off after you turn the key. otherwise it will stay on. And he doesnt mean ON as in start the car. Just in the first position where the radio and such turns on.
Old Feb 22, 2011 | 04:07 PM
aznboi2424's Avatar
Until the dash comes on, in the "ON" position.
The radio will still turn on in the "ACC" position.
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
pozebly
Sep 23, 2015 07:30 AM
coykiam
Sep 11, 2015 03:43 PM
HeloDown
Sep 8, 2015 06:51 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
