Magnaflow 14832 amazon
Lives in Boost
Quarantuning
From what I understand the exhaust shop needs to weld a flange to the end of the muffler so it will bolt up to the other flange on the stock y pipe. I'm assuming they would have to add some pipe as well to make it fit right. This way they can be bolted on and off if needed to return to stock.
Can someone with these exact mufflers and stock pipes post a pic from underneath to show how the installation was done?
Just curious... Thanks
LFG RANGERS!!!!!!!!!!!
These are 2 1/4 inlet. I am not using the stock exhaust. I am having 2 1/4 pipes mandrel bent by a custom exhaust shop from the cat back to these.
http://www.bromleysauto.com/Exhaust.htm
That's the shop. I have an appointment for next Friday
I hear ya talking. Last year when I put on my intake, header and crank pulley I said I was done to. Some how this summer I ended up doing A LOT more.. lol
I do still have the suspension to do, I have the springs & shocks & need sways but that won't be done until next year because I am moving and then the holidays are coming. Lots to do.
To the engine? I forgot I have Power Rev spacer & Thermal Gaskets and may do the plenums, What else outside of FI is there?
dude just get the 2.5 now and leave it. No need to waste money. The 2.5 wont hurt it. I mean if there is a huge price difference between 2.5 and 2.25 piping them I would understand.
![Flame](https://acurazine.com/forums/images/smilies/flame.gif)
That's Racist
How come these magnaflow 14832's are only $80 bucks
http://www.amazon.com/Magnaflow-Exha.../dp/B000CCG082
great price, i think liek a year or two ago it was standard to see these cans run for $149-$200
I'm ordering two of these soon. How much would the installation be do you think? Also do you think I should get mandrel bent or is it not worth it?
Here are the specs:
http://www.magnaflowexhausts.com/pro...productid=6564
Muffler with Tip, 2.25 in. Inlet/4 in. Outlet, Stainless Steel, Polished, Each
Brand: MagnaFlow
Product Line: MagnaFlow Performance Mirror Finish Stainless Steel Street Series Muffler and Tip Combos
Part Type: Mufflers
Part Number: MPE-14832
Case Shape: Oval
Inlet Diameter (in): 2.250 in.
Inlet Quantity: Single
Inlet Location: Center
Outlet Diameter (in): 4.000 in.
Outlet Quantity: Single
Outlet Location: Center
Internal Construction: Perforated stainless tube with packing
Muffler Material: Stainless steel
Muffler Finish: Polished
Case Length (in): 14.000 in.
Thickness (in): 5.000 in.
Width (in): 8.000 in.
Outlet Style: Double wall
Quantity: Sold individually.
Brand: MagnaFlow
Part Type: Mufflers
Case Shape: Oval
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
