Location to plug in code reader?
Friends, I borrowed a code reader from a buddy and plugged it into the plug under the steering column-all it shows is "no code" and gives RPM/MPG/etc info. Is there another location for a code reader to plug into?
dont know about the spot ur describing the , plug in should be below the thing in the middle that says this is not an ash tray , with red felt liner , theres an l shaped peice of plastic below that that will pull out and give u access
Wide Body 3.2 CL-S
right below the coin place. next to heat seat control switch. the stick ur hand in there and pull the plastic L shape platic. u will find obdII reader port
Except the 03. That has it under the steering whee.
fuzzy- not to sound ignorant, but what does CEL mean? Thanks. If it reads no code, and the VSA,ABS, and /!\ lights are on, doesn't that mean i only need to have something reset? Thanks.
CEL is NOT on. Shouldn't be the tranny, the lights came on directly after I broke the left front ABS speed sensor when replacing the steering knuckle....I installed a new one....
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
cak165
1G TSX Problems & Fixes
09-16-2015 08:17 PM
