lights on CC and heated seats out
the lights that indicate that the cruise control and heated seat(drivers only) have gone out on my car. is it a fuse, or a bulb? something i can fix or is it a dealer job. options still work, just would like to have them lighting up properly.
i leave them ou most of the time, even the CC when not in use, probably the causeanyone else have these problems
its just a bulb. remove cruise control switch by pulling out that black trim around the cluster/ac controls . not all the way out but far enough for you to stick your hand behind the Cruise switch and pop it out . then there is a bulb on teh left side of the switch.
same thing withe seat heater(if it is teh bulb but as long as heater works thats what it is ) . remove OBD2 cover (under the coin tray) then pull up/pry up trim that goes around the heater switch. this is a bitch to do since you got no room to work with . sme thing need to be done stick your hand as far back as you can and push the sitch out .
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
rockyboy
Jan 25, 2016 06:00 PM
