Lighting Question
Old Nov 24, 2002 | 08:29 PM
Seattle Cl-S's Avatar
Blown LS6!!
Lighting Question
I just had a bulb blow out in my fogs (only installed about 3 wks ago). I have the fogs tapped (the "on" wire, not power) into the side marker bulbs so that when you lock the doors, the fogs flash a couple of times. I'm assuming that accounts for the short life of the bulbs. Would it be ok if I tapped the fogs into the xenons so that the fogs only turned on when the main headlights are on???
Old Nov 24, 2002 | 08:37 PM
TheModMole's Avatar
13 Second CLS Defender :)
Dont play w/xenons at all.... wire to park lights... how often doo you drive with parking lights on????? they shouldnt be on unless your hedlights are on anyway
Old Nov 24, 2002 | 09:10 PM
Blown LS6!!
As I said before, the parking lights flash when you lock the car...causing the fogs (which are currently tapped into the parking lights) to flash also...leading to premature bulb failure. Is there any other way to tap the fogs so that they turn off when the car or lights turn off???
Old Nov 25, 2002 | 08:56 PM
Blown LS6!!
I went ahead and put the 'switch' wire to tell the fogs to turn on directly into the front-right xenon fuse. Will this harm the headlight or the fuse? It works perfectly for me so I hope this is an OK thing to do...
mada51589
Jan 9, 2025 04:40 PM
eastcoastguy
Sep 24, 2015 02:07 PM
wusty23jd
Sep 24, 2015 11:41 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
