Are light weight front brake calipers available ?
Are their any manufacturers selling light weight calipers for our cars without stepping up to larger rotors ?
Or how do I go about figuring ones that could be used for our cars ?
Bonki' Ehrite!
Whats your reasoning for wanting light weight calipers? They are un-sprung weight and not rotating mass. Plus, if lighter they are most likely thinner material which may not hold up well in serious heat cycles.
And as far as figuring out a one off set up, I'd contact someone like Master Power Brakes to help you out, they specialize in custom brake apps.
I don't want a huge fancy setup just a super light weight small caliper that will have the same braking power as I have now.
Master power brake have a site ?
Former Sponsor
We offer our XLR8 brake kit by STOPTECH. Yes it does have a larger rotor but it is a complete solution that will dramatically improve braking. I'd have to measure the exact weights again. I believe it was lighter than the stock setup
http://store.excelerateperformance.c.../i-533156.aspx
Just some basic info below.
XLR8 Touring Big Brake Kits are essentially StopTech® Touring Big Brake Kits®. These kits are the ultimate in 1-piece rotor brake upgrade systems and represent the best performance value in the StopTech® lineup.
They offer nearly the same performance as the StopTech® Big Brake Kits and Trophy full race systems at a more affordable price point. Designed for street driven production vehicles, StopTech® Touring Kits include forged 2-piece calipers, larger 1-piece rotors, StopTech® Stainless Steel Brake Lines, StopTech® Street Performance Brake Pads and application-specific caliper brackets.
The stiff 2-piece, fully-forged calipers have designated piston sizes specific to each application and provide a firmer, more responsive brake pedal that provides better brake pedal modulation.For this application, the Touring Big Brake Kits® is available in a four piston configuration and 5 different caliper colors that use a special high temperature paint to withstand extreme conditions. All StopTech® Touring Big Brake Kits® include stiff calipers that utilize silicone dust boots to extend service intervals.
The larger 1-piece rotors, available in Power Slot® slotted, or StopTech® SportStop® drilled finishes, provide greater heat capacity and reduced brake fade. Also assisting in fade resistance and higher performance are the StopTech® Street Performance Pads® which have a high maximum operating temperature, and high bite for responsive brakes that can be driven hard.
Bonki' Ehrite!
I know Carmen who started the company back in the 80's and Angel who works there now. They primarily do classic car stuff but they do a lot of custom sizing and fitting which may be a help in your situation
mada51589
Jan 9, 2025 04:40 PM
asahrts
Sep 4, 2015 05:55 PM
