lifters
Old Oct 18, 2005 | 12:03 AM
clsironhead's Avatar
Member this
lifters
i hear the lifters on my 03 six speed just wondering if warranty covers it. and if not how much do you think it will cost me.
Old Oct 18, 2005 | 12:17 AM
ghost_masterCL's Avatar
lifters?
Old Oct 18, 2005 | 12:30 AM
Hobo's Avatar
Flap.
i dont think they cover valve adjustments
Old Oct 18, 2005 | 07:54 AM
fuzzy02CLS's Avatar
They should. I had mine done on the old 6 speed.
Old Oct 20, 2005 | 06:52 PM
Member this
ill call and try to make an appointment see what they say
Old Oct 20, 2005 | 07:42 PM
spdy0001's Avatar
I now drive an accord....
You are probably just hearing the normal ticking that every CL does. Can you hear it from inside the car when driving? or just when the hoods open
Old Oct 20, 2005 | 10:24 PM
mclarenf3387's Avatar
Depends on the mileage. If you have 20k miles, they may cover it but if you have 60K+ they probably won't.
Depends on how loud is it. Like spdy said, can you hear it from inside the car or just when the hood is open?
Old Oct 20, 2005 | 10:55 PM
thedream21479's Avatar
Yeah, that ticking is the sound of the fuel injectors firing away--if that's the noise you're hearing, it's normal as he said.
Old Oct 21, 2005 | 03:01 AM
Chopsie's Avatar
Beware of leakage
unless your hearing it in the car, or the idle doesn't sound smooth, you need not worry.
Old Nov 2, 2005 | 11:06 PM
Member this
i can hear it from inside the car at idle and low rpm but goes away under power , maybe because of the road noise and the exhuast.
Old Nov 3, 2005 | 07:51 AM
fuzzy02CLS's Avatar
It may not be the lifters. Is it a ticking noise you hear with the ac & radio off at idle from inside the car?
If it is, it might be something called a purge solinoid valve. It's mounted on the firewall which is why your hear it from inside the car. What it does I don't know, but mine was ticking & replaced & the ticking went away.
Old Nov 3, 2005 | 03:54 PM
6MTpromises's Avatar
Relax!
Im glad you brought that up. Cuz mine only makes the ticking noise when the engine is warmed up, not when its cold, so I would think that rules out the injectors. Does yours do that too, Ironhead. And at idle its a very slow tick. I would think if it was the lifters or valves you would hear a lot of ticks per second.
Im only at 40k miles, Im gonna have to look into the PSV. Funny thing is I swear i can hear it through the intake manifold, not near the firewall.
Old Nov 3, 2005 | 09:05 PM
TypeSleeper's Avatar
I may be wrong but I didn't think over-head-cam engines had lifters.
Old Nov 3, 2005 | 09:39 PM
spdy0001's Avatar
Yup, there are lifters even in the OHC engines
Old Nov 4, 2005 | 10:09 PM
jgscott's Avatar
I think he's right. OHC engines may have lifters but.... I don't think the CLS engines have lifters.
Old Nov 4, 2005 | 11:25 PM
Type S Zero's Avatar
J32 don't have hydrolic lifters, they have roller-rockers.
roller rockers don't need to be ajusted as frequently as direct rubbing rockers (every 30K miles), but J32's at 60K miles should be re-ajusted (we inspected a few for fun on the 60K maintenace inspection and they all needed to be ajusted).
the purge solenoid valve never opens at idle or acceleration
some injectors are noisier than others, and louder ones sometime sound near highly gapped rockers on 4 cyl engines
Old Nov 4, 2005 | 11:48 PM
MotionEffects's Avatar
Acura TLS are SLOW
Theres no lifters in OHC motors. The whole concept of OHC motor is to get rid of pushrods and lifters. Lifters are only found in inblock cam motors like vettes, camaro, etc.
Old Nov 7, 2005 | 10:02 PM
jgscott's Avatar
Ok now I'm not sure about this one because, I think my 93 Ledgen 3.2 Type II was OHC and it had Lifters. I think ?
Old Nov 8, 2005 | 05:51 PM
RooEng's Avatar
Yes there are lifters in an ohc engine. They don't look anything like a ohv lifter but they do ride on the cam and transfer rotational motion of the cam to open and close the valves. Most of the DOHC Toyota engines I build have them but the the sohc engine in our Acura's have only adjustable rocker arms between the cam and valve, no lifters or pushrods.
Sometims V8 terminology just doesn't directly translate into import language.
Old Nov 9, 2005 | 07:52 PM
Acura TLS are SLOW
You are talking about Cam Followers. They may look like lifters but not classified as one. People sometime call them bucket lifters, i dunno why. but BMW is a big fan of using them.
Old Nov 10, 2005 | 09:21 AM
kbc5960's Avatar
Most likely your valves need adjusting. I had the same noise on mine. Warrantly does not cover it, and it will cost you about 300 to 400 dollars to get the valves adjusted.
Warranty should cover it, but Acura considers it as maintenance work. I went through a whole discussion with Acura Corporate over this. Bunch of punks IMO... Valves should not need to be adjusted at 30k miles.
Old Nov 10, 2005 | 09:27 AM
they SAY they should be done at 1xx,000 miles, but really should be done every 30k-60k miles depending on how hard you drive your car.
Old Nov 10, 2005 | 09:29 AM
fuzzy02CLS's Avatar
Well, depends on your dealer really. If they want to cover the valve adjustment they will. I had them done on the old car under warranty. Had to fight for it though.
Old Nov 11, 2005 | 12:00 PM
Member this
mine does the same thing when warm is when i hear it the most , not when its cold its very annoying. it dont think it coming from the fire wall. i have 53,000 miles on it i hope the dearler can do something if not im screwed and have to come up with the loot.
alfadoctor
Jul 5, 2010 11:18 AM
Brwn28875
1G TL Problems & Fixes
Jun 4, 2010 11:51 AM
rdevillers
Feb 23, 2009 06:08 PM
Inaccurate
Jun 21, 2006 09:13 AM
SpeedyV6
Jan 22, 2004 01:54 PM
