Legitimate question reqarding jack stands
Old Mar 21, 2003 | 10:31 AM
DDT-TypeS's Avatar
6SPDCLS
Someone please help answer this question:
I have purchased a 4 ton hydraulic jack AND a pair of jack stands. Now the question is how do you supposedly jack the car up to a fair height in order to place the jack stands underneath the each of the two side jack points under each of the sides? I know in the car manual there are four (4) total points in which you would use the car jack but if I use the 4 ton jack, there is no point to jack up the car!
When I had to install the comptech sways, I had to use a brick to jack the car up. I do remember seeing the jack points in the front and rear of the car (underside) but I don't have that manual with me. It's not in the consumer manual but it's in the technical manual (the one you buy).
Anyone have that diagram of where to place jack to lift car? I couldn't find it in the useful topic and search.
Thanks!
Old Mar 21, 2003 | 10:34 AM
NOLACLS's Avatar
What I have seen before on other cars is find a spot in the front of the car so you can jack it up with out useing the jack spots...that way once the car is up you can put the stands in place. Dont quote me on this because I am not sure if it is the right way...but I have seen it done with out problems on other cars.
Old Mar 21, 2003 | 10:36 AM
4pumpedCL's Avatar
Honkey
I lift mine by the front crossmember and the rear tow hook.
-Aaron
Old Mar 21, 2003 | 01:13 PM
tdtsai's Avatar
I would put the jack next to the jack point of the car and bring the car up and put the stand under the jack point. This is what we did with my brother's Passat. This is probably the safest way to go about it. I wouldn't know where the jack point is under the engine and it would very risky if you made a mistake
Old Mar 21, 2003 | 01:18 PM
sidemarker's Avatar
front tow hooks is the perfect place to jack the car up
JUST REMEMBER TO PUT ENGAGE YOUR E-BRAKE AND PUT SOME STOPPERS IN THE REAR!!!!!!
sidemarker
Old Mar 21, 2003 | 01:38 PM
NOVAwhiteTypeS's Avatar
can someone post a picture where the front tow hook is?
I used the stock jack to get the car just high enough and then used my hyd. jack
Old Mar 21, 2003 | 01:41 PM
Shawn S's Avatar
NO NO NO NO NO NO
Do not jack the car up there.
Thase are not designed to hold the car.
The REAR one YES, the FRONT ones NO !!!
Shawn S
PS.... Stand by. I'll find some photos for you
Old Mar 21, 2003 | 01:46 PM
Shawn S's Avatar
Old Mar 21, 2003 | 01:49 PM
Shawn S's Avatar
There YA go.
Use the REAR tow hook to jack the back of the car and put your stands in place at the factory spot.
For the FRONT, use the spot just forward of the engine directly in the middle of the car and then place the stands in the factory lift positions.
Shawn S
Old Mar 21, 2003 | 01:56 PM
Scrib's Avatar
Administrator Alumnus
Would this be a good approach for installing sway bars? I'm assuming next weekend will be the time I put them in. Are there clearance issues that I'll need jacks or something similar?
Old Mar 21, 2003 | 02:01 PM
DDT-TypeS's Avatar
6SPDCLS
Originally posted by Shawn S
There YA go.
Shawn S
Damn, thanks a million guys...Shawn: That is EXACTLY WHAT I WAS HOPING FOR...thanks a million for the pics..it helps so much!
For the rear, I didn't know how high to jack up since I am new to the 4 ton jack, I didn't know if it can extend as vertical as yours (almost 90 degrees it seems). As for the front, I'll look underneath to see if I can find that point to use the jack. I saw it in the tech manual but I forgot all about it.
Thanks! you the shet!
Old Mar 21, 2003 | 02:34 PM
tdtsai's Avatar
Very important! Don't forget to chuck the wheels BEFORE jacking
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
SUPRMN84
Oct 7, 2015 09:46 PM
navtool.com
Sep 25, 2015 05:15 PM
