legend caliper question
I was curious if these are the right legend calipers for our car?
http://www.autopartswarehouse.com/de...Q24S01006.html
they dont really say whether they are dual piston or not, but they say fit a 95 ls.
Yea they are expensive, i wasnt gonna buy those exact ones. I called and those aren't even the dual piston ones anyway. I called autozone and they can order me the 95 legend gs calipers for 52 each. I'm still not sure if i want to go the legend route or get the front wilwood bbk thats 775$. Money is an issue, and also the wilwood doesn't fit behind stock wheels without a 15mm spacer(I put stock on for winter). I might need new bolts too. That would be pricey. Im gonna price both out and see the cost difference.
Im looking at basically 3 options now.
1. Wilwood 12.6" front bbk($775), rear rotora brake lines($67), ebc red pads(151), and rear rotors(used ebc sport as an example($188)) =$1181
2. Legend Calipers($104), front rotor DBA 4000($237), rear rotor EBC sport($188), EBC red pads($151), goodridge lines($125) =$805
3. Legend Calipers($104), front rotor EBC sport($180), rear rotor EBC sport($188), EBC red pads($151), goodridge lines($125) =$748
Also if i go with the Wilwood i will have to run wheel spacers and maybe get extended studs when I have the stock wheels on for winter. The eibach 15mm spacers are $140 each so thats another $280 there. Will it look stupid with 15mm spacers on front but none on the rear? Also if I get Legend I might pay $50 to get the calipers powdercoated. What do you guys think I should do. I want the wilwood but the extra cost plus dealing with spacers is a turn off. The Legend would probably be enough for my driving style but i don't wanna buy them and regret not getting wilwood in the future.
I originally looked at those legend calipers as well. Those aren't the right ones, and they are def too much! Check your local Nappa, Autozone, or Advanced Auto for referb calipers. Make sure they are the '95 Legend LS because the base model still had the single piston. They will be dual piston and look much diff then the single piston. After my core charge refund they were less than a hundred each (before my discount) at Advanced.
'95 Legend LS Calipers - about $75 each
R1 Racing Slotted and drilled rotor/pad package - $300 shipped
Caliper Paint & Clear - $15
Misc supplies for painting (tape, plastic drop cloth) - $20
TOTAL = $485
My biggest reason for the upgrade was all the highway driving i do and warping rotors like it was my job. I've had these on for months and have about 20K on 'em with perfect results! Perfect wear on pads and rotors, no cracking or anything. Stops like a beast, and they are smooth, quiet, and strong in the pedal. Couldn't be happier with the results.
As long as they are the '95 Legend GS, and he says they are dual, then your good. Its just that year from the Legend that happen to bolt right up to our stock brackets. No modding needed. This is my setup:
TOTAL = $485
TOTAL = $485
no, the legend calipers are a direct swap to the oem cl calipers. Dont need to replace anything. Just make sure you get the right ones dual piston from 95 ls or gs.
I must be really easy on the brakes cause after 88k miles i've never warped or replaced my rotors. I lik driving aggresively, its just that I usually wait for open roads to go fast where i wont have to brake hard. I still wanna upgrade my brakes for performance and cosmetic reasons tho. I am gonna put new wheels on in spring and all the rust behind the wheel is a turn off. i will drive more agressively once i put all my mods on also. On a side note, after driving a car with a brembo big brake kit 6 piston calipers the cl brakes really seem like garbage.
HOLY SHIT!! so i CAN change the brakes to dual piston, and leave the pads and rotors!!! woohoooo!
this shall be my next mod! after I find a reasonable price on the calipers FUCKING SWWWEEEET.
HOW much BETTER does the car brake after adding the dual piston calipers?
Yeah its really strait forward. Swap, bleed, bed pads and rotors, enjoy!
Brian is correct, you can use the stock sized rotors. Unless you resurface the existing i wouldn't recommend using the same ones with the swap. Start fresh, with new rotors and pads.
Ill probably go with the legend calipers over a bbk for now. I can't really justify over 1k on brakes. What is preferred for this install left caliper on right etc or just bleed it upside down. Anyone have suggestions for other good performance pads besides the ebc reds. I thought I heard carbotechs are good.
well i just bought top of the line ads from napa. Adaptive one they are called. Front and back. The pads are virtually new, and rotor the same... wear is absolutely PERFECT, which is why i might hold off. But i'd love to do stainless steel brake lines and these calipers.
I will not switch the rotor and pad however if I do go ahead with this mod soon.
But honestly for the times I stop hard the car stops HARD, abs kicks in so fast... one the pads/rotor have heated up a lil. (when it is near zero, between the DBA rotors and high performance pads, it's had to heat them up.. so u gotta be driving for a lil before everything is good to go.) I want to swap lines and front rotors to eliminate this problem, which i firmly believe it would, using the same rotors and pads.
I spent 450 on the front pads and rotors, which are bedded perfectly and not a even the slightest bit warped. So if I change I will keep that stuff I cannot see what the issue would be? can anyone fill me in?
I'm rocking racing brake slotted rotors, legend calipers, racing brake 500 pads, goodridge lines, with ATE super blue fluid. Love my brakes, and no spacers needed as I swap to my stock wheels in the winter.
i dunno about in canadian funds but i was quoted 52 each. i was told since the calipers are different ones I cant do the core return but maybe you can get away with it. Also you need to go to the store and pay for it up front before they order it.
and these remanufactured calipers are going to be as good as new basically? I don't have to worry about uneven pad wear... etc?
caue right now my brakes are mint and if i change them I don't wanna have any problems. I HATE causing a problem when doing a mod
k well now i know my mods for this year... XLR8 Cat, comptech mufflers, stainless steel brake lines, and legend calipers.
that'll be enough to keep me happy.... hopefully
Out of all the reman calipers I have gotten on all my cars. I haven't ran into any problems. Almost all the cores are OEM with Nissen stamped on them and when they tear the caliper down to rebuild, its just the piston and gaskets. There really isn't that many moving parts in a caliper. Piston in, Piston out. Just make sure you lube the slides as its common on imports for them to seize.
ok just making sure I'm not gonna create a problem :-)... i'm gonna leave this mod till later tho. right now my brakes are fine imho. So no RUSH for now. but it's definitely on my to do list.
I went to autozone it was actually 95 each for the 95 GS ones. The 52 each was after the core refund. I hope I can return my cores otherwise these will be a lil pricey. Should have them in tomorrow.
Also when i was in i had him look up the caliper for the 95 LS and those were single piston. There were no options for coupe, just sedan. So if your looking for these I would look under 95 Legend GS sedan.
Are you guys running the R1 concept elian ones, cause the premiums are pricey? Also how good are those? All 4 rotors would only run $200 seems cheap. Thats less than the cost of just DBA fronts. Dunno what pads to get yet.
I just looked up R1 concepts and the first thing i saw was this article about a cracked rotor after 1k miles. http://www.clublexus.com/forums/susp...-2-months.html
I dunno about that brand after reading this. Do you recommend blanks, slotted, or drilled and slotted?
i have the db 4000xs... when u get them in ur hand u'll see the quality.
http://www.dba.com.au/2006/PDF_CATAL...e_2009%201.pdf
check them out
check them out
check them out
check them out
yep, drilled = wait for it to crack.
Drilled rotors just are not need these days with its technology behind the pad compounds. Back in the day, there would be gas build up from braking at the track which would create a slick contact with the rotor. At that time, companies created drilling the rotors to release the gases. IMHO, drilled rotors are just a waste now besides the bling factor. Slotted rotors are going to cut into the pads to provide fresh contact every time. To much? just get some brembo blanks.
