LED turn signal questions...
Old Apr 21, 2010 | 10:26 AM
evan03CL's Avatar
Wait...I just blacked out
So I bought some LED turn signals for my front bulbs, and not only are they doing the "hyper blink" thing, but they're also only lighting up when I have the turn signals on. (and when I put the hazard lights on)
Any ideas of why this could be? Also, anyone have any info on where to get, and how to install, these "load resistors" to stop the hyper blinking?
Old Apr 21, 2010 | 12:05 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
You can get load resistors that tap right in to the stock wire, as for the bulbs not lighting up, try flipping them around they may be polarized
Old Apr 22, 2010 | 08:49 AM
MrFluffy's Avatar
To many cars in my garage
I had this same problem I ended up just going with a custom setup but it still blinks as if it were out
Old Apr 22, 2010 | 03:14 PM
civicdrivr's Avatar
Incandescent FTMFW!
Old Apr 23, 2010 | 12:03 AM
kdawg8526's Avatar
13.2@106mph G37 RWD Sedan
you need to get load resistors and wire them to the wires going to the bulb
Old Apr 23, 2010 | 01:15 AM
dave586270's Avatar
Chamorro
I have an easier fix for you, I put in the switchback LED's. You just need the new flasher unit:
http://www.v-leds.com/BlinkerWarning...-p4481117.html
Problem solved! Its located under the steering wheel on the left side (pretty much under the fuse panel. Just turn the signal on to get down and hear where the clicking is coming from. You'll have to take the case off the new flasher for it to fit into the plug. GL!
Old Apr 23, 2010 | 01:16 AM
dave586270's Avatar
Chamorro
Old Apr 23, 2010 | 06:24 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i hate the quick blink thing.. considering u cannot even put LEDs in our car without having this stupid resistance problem, I just don't see the opportunity vs cost. or else i would have done this longggg time ago
Old Apr 23, 2010 | 01:30 PM
evan03CL's Avatar
Thanks for the help guys, I knew i'd encounter the fast blink problem but why are they not staying lit? When i put in the old filament bulbs they stay lit...
Old Apr 23, 2010 | 02:33 PM
(Mid-Atlantic)
This is what I plan to get as well, next time I make an LED order
Old Apr 23, 2010 | 09:30 PM
dave586270's Avatar
Chamorro
evan: I had the same problem when I put in my LED switchbacks. The flasher just doesn't know what to do. I'm telling ya, just pick up the new flasher relay, replace the old one with it and you'll be all good!
Old Jan 23, 2012 | 07:49 AM
dcguy's Avatar
Was it ever discovered why the bulbs did not stay lit?
Old Feb 5, 2012 | 05:03 PM
dave586270's Avatar
Chamorro
Needs new relay, mine did the same thing. They system thinks the bulb is burnt out because it uses such little power. New turn signal relay will fix it.
Old Mar 2, 2012 | 07:41 PM
_demons_79_'s Avatar
8th Gear
dave which model switchback did you use? I know its the type 1 but is it a 60 or 92?
Old Apr 8, 2012 | 04:12 AM
dave586270's Avatar
Chamorro
I have the 60 bulb ones in my car. The 90 are newer. just more bulbs.
Old Apr 26, 2012 | 11:06 PM
8th Gear
Did they fit right in without modification?
Old Jun 14, 2012 | 04:57 PM
dave586270's Avatar
Chamorro
Hey sorry for the late response, I'm sure you figured out by now that they fit just fine. No issues at all, enjoy!
pplcrew
Jan 30, 2021 08:59 AM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
JnC
Sep 11, 2015 06:06 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
