LED dash lights and interior lights - Doable?
Old Nov 21, 2012 | 12:29 PM
Mopply's Avatar
I've grown tired of the yellowish-green lights on the dashboard and I'm really into the idea of changing them out for LEDs. Also, the door lights and the center light I'd like to switch to white LEDs. Is this switch doable, as in a DIY job? What LEDs do you guys recommend for this sort of swap?
Old Nov 21, 2012 | 03:03 PM
aznboi2424's Avatar
It's easy to do with the door lights and center console. You just need to purchase the replacement LED equivalent bulb for these lights online. If you can change an automotive light bulb, then you can do this.
As for as the lights on the dash, the bulbs are installed a little differently but it's the same concept. Harder to gain access behind the dash though, vs taking off the cover for the door or center console lights.
Old Nov 21, 2012 | 03:18 PM
Mopply's Avatar
Oh okay. So basically the dash lights will be where the time goes. Are the lights just a bunch of small bulbs lighting up their section? And I'm thinking of blue for the dash lights to give it a more modern appearance. Any suggestions?
Old Nov 22, 2012 | 12:35 PM
mikebikelife's Avatar
@Mikeshlong On IG
Here , this should help .
I don't know what led bulb number you would need, but if someone finds the answer please chime in...
https://acurazine.com/forums/2g-tl-problems-fixes-117/dash-clock-light-out-621510/
Old Nov 22, 2012 | 09:42 PM
OperationDarkie's Avatar
Ultra Negro
All my interior lights are LED as well as my plate light is an LED, I don't think I will do the dash though, not a fan of bright light on the dash, just the interior lighting to be light.
Old Nov 22, 2012 | 10:39 PM
Mopply's Avatar
Where did you get your LED interior lights?
Old Nov 23, 2012 | 11:43 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
www.superbrightleds.com
Old Nov 26, 2012 | 02:21 PM
aznboi2424's Avatar
The problem with going to a different color is that you'll also need to remove the colored film. The bulbs are normal bulbs so there is a colored film that make it that light green color. Remove the film and replace with blue LEDs and that should work. Another issue maybe how the light of the LEDs refract. LEDs can only shoot light off in one direction.
Old Nov 26, 2012 | 05:55 PM
Mopply's Avatar
Hmm maybe I'll just change the colored film then to blue or something.
Old Nov 26, 2012 | 06:00 PM
fsttyms1's Avatar
You can't just change the colored film. Its printed on the gauges. You can carefully remove it then use what ever color bulb/led you want.
Old Nov 26, 2012 | 06:02 PM
Mr Marco's Avatar
Seems like a ton of work for little reward. How much faster will the car be if you do this mod?
Old Nov 26, 2012 | 07:09 PM
Mopply's Avatar
Um... Not sure if calling me a ricer or wrong thread post. Either way, I'm not a ricer, just trying to update the cars looks a bit.
I think I'm just going to deal with the lights.
Old Nov 27, 2012 | 09:34 AM
@Mikeshlong On IG
Don't get discouraged man , not everybody is going to agree with what you like . Do it if you wanna do it , if not the lights are sufficient already .
Old Nov 28, 2012 | 06:51 PM
aznboi2424's Avatar
LEDs look sick in the dash and gauges. Especially in white.
Old Nov 28, 2012 | 07:35 PM
Mopply's Avatar
I'll look into it more. I gotta find out the sizes of the lights that'll fit and all that right?
Old Nov 30, 2012 | 08:42 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
LEDs give off less of a visible light spectrum usually. Unless u get some super dooper high efficiency one. Cause i put a so called good one by the license plate and it produces a third the light..
likewise i did my interior dome lights and instantly noticed the LACK of ambient light.. yes it looks cool but functionally it's garbage.
so from my experience, LEDs are not as great as I thought.. however they do produce more light for the electrical input. therefore LEDs are great if u can use a lot of them in place of one incandecent.
Old Nov 30, 2012 | 10:41 AM
@Mikeshlong On IG
My dome light went hallogen, 2 light led , 8 light led . The 2 light sucks, the 8 is way better than the hallogen.
Old Nov 30, 2012 | 04:35 PM
aznboi2424's Avatar
Exactly. Thats why in the LED gauge conversion DIY, you wire in like double or 3x the amount of bulbs in a stock cluster.
Old Nov 30, 2012 | 04:52 PM
fsttyms1's Avatar
This is what mine looks like. I still have to get back in there and finish it. I need to illuminate the odo better and adjust a few of the white lights. Getting pictures accurately is hard, in person its much better looking.
Blue switched off and switched to red
background lighting off
Old Dec 1, 2012 | 01:15 AM
Mopply's Avatar
The blue looks sick! I gotta do this now! What was the average cost of doing this and how much time estimated?
Old Dec 1, 2012 | 01:21 PM
fsttyms1's Avatar
I had maybe 40 bucks or so in LED's? Time? depends on how hard you work at it. I had maybe 8 hours start to finish? Carefully removing the color off the back of the gauges took the longest. You have to use something like Graffiti Remover, but if you touch the front of the gauges you will take the finish off of it so TAKING your time on this part is the hardest part.
Old Dec 1, 2012 | 07:56 PM
@Mikeshlong On IG
Have a link as to where we could buy bulbs ?
Old Dec 4, 2012 | 11:10 AM
(Mid-Atlantic)
Old Dec 4, 2012 | 11:24 AM
Insedanity's Avatar
That looks phenomenal, nice work!
I got a LED interior light kit from a guy who works at Delphi Packard, he helped design the kit as it was to be the one to go in the new Mustang (contract ended up going to a Chinese supplier, buy Ford/American, lol). It changes colors on demand or can lock on one color. I have it installed in the footwells and in front of the back seats (if that makes sense) and would love to do my dash like yours to match.
Old Dec 5, 2012 | 01:54 PM
you know what pisses me off??
how does the cl not have foot well lighting when u open the doors..
my POS ford probe had that!!! and it had motorized lumbar support...
but the absence of foot well lighting has always pissed me off personally.
im really surprised no one on the site makes a stink about it. only think i have heard one person talk about it on zine ever
Old Dec 5, 2012 | 02:37 PM
(Mid-Atlantic)
My CL has foot well lighting
Old Dec 5, 2012 | 10:16 PM
and that just aint right :-)
Old Dec 6, 2012 | 08:07 AM
fsttyms1's Avatar
Add it on your own? Pretty easy and cheap to do
Old Dec 6, 2012 | 08:08 AM
fsttyms1's Avatar
Thanks.
I want to redo mine so that the tach lights up as the needle swings up some how.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
