LED dash lights and interior lights - Doable?
I've grown tired of the yellowish-green lights on the dashboard and I'm really into the idea of changing them out for LEDs. Also, the door lights and the center light I'd like to switch to white LEDs. Is this switch doable, as in a DIY job? What LEDs do you guys recommend for this sort of swap?
It's easy to do with the door lights and center console. You just need to purchase the replacement LED equivalent bulb for these lights online. If you can change an automotive light bulb, then you can do this.
As for as the lights on the dash, the bulbs are installed a little differently but it's the same concept. Harder to gain access behind the dash though, vs taking off the cover for the door or center console lights.
@Mikeshlong On IG
Here , this should help .
I don't know what led bulb number you would need, but if someone finds the answer please chime in...
https://acurazine.com/forums/2g-tl-problems-fixes-117/dash-clock-light-out-621510/
Ultra Negro
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The problem with going to a different color is that you'll also need to remove the colored film. The bulbs are normal bulbs so there is a colored film that make it that light green color. Remove the film and replace with blue LEDs and that should work. Another issue maybe how the light of the LEDs refract. LEDs can only shoot light off in one direction.
Ghost44 (03-11-2014)
You can't just change the colored film. Its printed on the gauges. You can carefully remove it then use what ever color bulb/led you want.
Seems like a ton of work for little reward. How much faster will the car be if you do this mod?
mikebikelife (11-29-2012)
lowrd on tein CS biatch
LEDs give off less of a visible light spectrum usually. Unless u get some super dooper high efficiency one. Cause i put a so called good one by the license plate and it produces a third the light..
likewise i did my interior dome lights and instantly noticed the LACK of ambient light.. yes it looks cool but functionally it's garbage.
so from my experience, LEDs are not as great as I thought.. however they do produce more light for the electrical input. therefore LEDs are great if u can use a lot of them in place of one incandecent.
@Mikeshlong On IG
My dome light went hallogen, 2 light led , 8 light led . The 2 light sucks, the 8 is way better than the hallogen.
This is what mine looks like. I still have to get back in there and finish it. I need to illuminate the odo better and adjust a few of the white lights. Getting pictures accurately is hard, in person its much better looking.
Blue switched off and switched to red
background lighting off
I had maybe 40 bucks or so in LED's? Time? depends on how hard you work at it. I had maybe 8 hours start to finish? Carefully removing the color off the back of the gauges took the longest. You have to use something like Graffiti Remover, but if you touch the front of the gauges you will take the finish off of it so TAKING your time on this part is the hardest part.
(Mid-Atlantic)
(Mid-Atlantic)
mikebikelife (12-06-2012)
That looks phenomenal, nice work!
I got a LED interior light kit from a guy who works at Delphi Packard, he helped design the kit as it was to be the one to go in the new Mustang (contract ended up going to a Chinese supplier, buy Ford/American, lol). It changes colors on demand or can lock on one color. I have it installed in the footwells and in front of the back seats (if that makes sense) and would love to do my dash like yours to match.
you know what pisses me off??
how does the cl not have foot well lighting when u open the doors..
my POS ford probe had that!!! and it had motorized lumbar support...
but the absence of foot well lighting has always pissed me off personally.
im really surprised no one on the site makes a stink about it. only think i have heard one person talk about it on zine ever
piro91 (12-30-2012)
(Mid-Atlantic)
(Mid-Atlantic)
I want to redo mine so that the tach lights up as the needle swings up some how.
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
