LED in corners question - relay?
Old Jul 19, 2010 | 08:58 PM
ceagles1000's Avatar
If I put LEDs in my corners will I need a relay to prevent my blinkers from flashing really fast?
Old Jul 19, 2010 | 09:50 PM
Rajca's Avatar
wham bam thank you ma'am
u will need resisters wired into the harness. OR if u search on the 2nd gen tl side, someone replaced the flasher relay with a slower blinking one. it was a few years ago where i read that.
Old Jul 20, 2010 | 08:20 AM
thanks!
the resistors in the harness - do I have to take out the whole headlight? is it a real pain? I searched the threads and I read a lot about changing the bulbs but no one talking about resistors. Maybe they werent using LEDs....
Old Jul 20, 2010 | 08:37 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
you dont have to take out the headlights, you can get resistors with wire taps and just tap them on the back of the turn signals
Old Jul 20, 2010 | 08:49 AM
is it easy? seems like it could be a pain, since there is no room.
i heard about changing the relay under the dash, that stops the hyper blinking. that seems easier
Old Jul 20, 2010 | 09:21 AM
Rajca's Avatar
^ u can do that. Just find the correct relay. Its not had taping into the turn signal harness, just not a lot of room in the fender. So it would be easier to take out the headlight or the fender lining
Old Jul 20, 2010 | 10:11 AM
thanks a lot. Seems like the relay is alot easier.
does anyone know the correct one? Ill search the boards
Old Jul 21, 2010 | 09:57 AM
Thanks for all the help. FYI: I found the relay under the dash, its the relay on the bottom. If you put your blinkers on you can feel around and its easy to find. It was tricky to get it out. Just get under there so you can see everything. There are 2 tabs one on top and one on bottom of the relay. When you pull them apart, you can take out the relay. Takes a good pull to get it out, a little bit of a pain, but not bad at all. I pulled it out to help me determine which one fits our car. Autoillumination has a lot of info on there relays and I was able to confirm the model # on my relay that matched there relay for LEDs
Old Jul 21, 2010 | 12:08 PM
Rajca's Avatar
So what's the correct relay we need?
Old Jul 21, 2010 | 12:24 PM
(Mid-Atlantic)
I'm interested to know this also, I got the "japanese" relay off of superbrightleds so I'd be interested to know for sure if it works
Old Jul 21, 2010 | 03:18 PM
civicdrivr's Avatar
Does the slower relay slow down the rear incandescents if you dont swap them to LEDs as well?
Old Jul 22, 2010 | 07:54 AM
if you use autoillumination this is the one you need
EP34 (CF13JL-02)
Old Jul 22, 2010 | 07:56 AM
led
Thats a great question. Im not sure but I dont think it would slow the incandescents down. I think it just slows down the actual clicking inside the vehicle. But Im not sure.
Old Jul 22, 2010 | 08:57 AM
Rajca's Avatar
Op, do u have leds in all 4 corners? Or just the front/ back?
Old Jul 22, 2010 | 11:08 AM
Im changing just the front corners. I got the swichbacks. Cant wait they look nice!!
Old Jul 23, 2010 | 08:59 AM
(Mid-Atlantic)
EP34 (CF13JL-02)
sweet, I have the CF13JL-02 from superbrightleds sitting in the garage, I will throw it in tonight, thanks for the info, glad to know I got the right one
Old Jul 27, 2010 | 02:12 PM
sdcls6's Avatar
any updates on the new blinkers?
01CLOwner
Oct 9, 2015 01:07 PM
Silverstead1
Sep 17, 2015 06:45 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
