Leak when it rains!
Old May 15, 2010 | 10:27 PM
dave586270's Avatar
Chamorro
Leak when it rains!
Alright, this was a horrible problem the other night, it was pouring out and i had a leak.
The water comes in from the Driver's side a-pillar where the plastic ends on the top and its just fabric. It was seeping through and dripping onto my leg!
Anyone else have this problem or know what the problem might be? I took the plastic cover to the pillar off but couldn't trace the problem...
Old May 15, 2010 | 10:52 PM
civicdrivr's Avatar
Sunroof drain tubes.
Old May 15, 2010 | 11:29 PM
friesm2000's Avatar
B A N N E D
so at the top of the windshield , but yeah more then likely plugged sunroof drains, especially common if you leave the sunroof open, even cracked, if you park under a tree alot and it drops all it's leaves on the car
Old May 16, 2010 | 12:22 PM
Rajca's Avatar
wham bam thank you ma'am
drain tubes most likely common problem
Old May 16, 2010 | 07:58 PM
ChucksCL-S's Avatar
Also check windshield gasket outside car in that area, look for gaps.
Old May 16, 2010 | 10:16 PM
newbster's Avatar
I know what you are talking about because I had the same exact problem. Its what everyone says it is-the drain tube. I was not able to resolve it so nowadays, I park on a slant with the front raised higher than the rear so that water will flow down the back and not affect the front drain.
A question for everyone else-my car is having some weird problem. When I put the car in reverse, the windshield wipers will come on and sweep a couple times and then shut off. Anyone else have this issue? It goes away when in drive...
Old May 17, 2010 | 01:25 AM
dave586270's Avatar
Chamorro
Sunroof drain tubes? WTF? We have sunroof drain tubes, lol? I've gotta check this out. How do I even check those, haha?
Old May 17, 2010 | 01:26 AM
dave586270's Avatar
Chamorro
Sounds like a bad relay, electrical issues are not fun.
Old May 17, 2010 | 04:52 AM
Rajca's Avatar
the drain tubes go back into the trunk and are behind the jack tools and that little pocket on the other side.
Old May 17, 2010 | 12:39 PM
civicdrivr's Avatar
There are also drain tubes to the front as well. I dont know how to check them though.
Old May 17, 2010 | 04:26 PM
dave586270's Avatar
Chamorro
Damn, i just got done clearing the front ones! Some compressed air and then water flowed perfect! I don't know how to get to the rear ones though...shit. I'm pretty sure it was the front one that was clogged. Haven't had any other water issues, thanks guys! Its supposed to pour the next couple days, we'll see how it goes!
Old May 17, 2010 | 06:14 PM
friesm2000's Avatar
B A N N E D
they go down the a-pillars, iirc they are inside the pillar though, but i think they come out right in front of the door though, behind the fender, so if you open the door you can see the end of them
Old May 17, 2010 | 06:16 PM
friesm2000's Avatar
B A N N E D
what some people do, to "solve" problems :shakehead
yeah proably the best way of fixing it, just blowing it out (might have had to blow it backwards, but sounds like you got it anyways though)
also might be worth it to blow out the rear ones also, better be safe then (or another leak), and iirc they come out behind the rear bumper on the side
Old May 17, 2010 | 06:20 PM
dave586270's Avatar
Chamorro
Yeah after I blew the air through it i poured some water into the lip under the sunroof (had it opened all the way) and it poured out with no problems!
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
