Knock noise
Old Sep 14, 2012 | 01:03 PM
dtdcampbell's Avatar
Knock noise
Just wanted to see if anyone can give some input on where I have a knock noise coming from. Basically it is in my steering and it can be heard when I turn my where back and forth. Which I think it is on the driver side.
Old Sep 14, 2012 | 05:23 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
ball joint
raise car up SAFELY
try to turn each wheel left right forward backward... u will likely feel a bit of play somewhere and it's likely going to be the ball joint
Old Sep 15, 2012 | 10:59 PM
yungone501's Avatar
J-series addict
This and I've also seen both the power steering rack or stabilizer bar mounts cause alot of racket. You can inspect all rubber bushings simply by turning wheel to the extreme left or right. If nothing obvious is seen, get a pry bar or large flathead screwdriver and wedge it between the points at which any metal suspension/steering components meet. If nothing is found, lift the car up, place jack stands beneath it and do the same underneath. Maybe even have somebody turn the wheel back and fourth while doing any of the procedures above...namely the visual inspection part.
Old Sep 24, 2012 | 07:08 AM
Shouldn't be the ball joints since I did those last spring when I thought those were making knocking noise. Which ended up being the sway bar bushings. I ended up replacing the front and rear for those since they had play earlier this summer.
This is a new noise someplace else and I think yungone501 probably is right with it coming from the power steering rack. Anyone have a possible part number that is related to the power steering so i know what to look at?
Old Sep 24, 2012 | 07:47 AM
u mean when the car is off still and when u dry steering there is a little click/click when moving wheel back and forth?
Old Sep 24, 2012 | 10:26 AM
Yea that is what it is doing. I know there are a couple noises that have started recently so trying to figure it all out
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
