Keep weatherstripping from cracking/discoloring?
Old 08-14-2002, 11:46 AM
gsrblack's Avatar
Is there anything I can put on weatherstripping to keep it from cracking or turning white in the sun? My friend's 2001 TL is doing it already and I don't want to see my '03 CL-S doing that in the near future...
Old 08-14-2002, 11:48 AM
KavexTrax's Avatar
the early 01's may have that problem but older '01s are fine (aug-sep01 and older).
You may want to see your dealer for a fix.
Old 08-14-2002, 12:15 PM
Shawn S's Avatar
I don’t know about CRACKING, but I always wipe a light coat of Johnson’s Baby Oil on the door gaskets in the fall.
This keeps the doors from freezing shut in the winter if it rains and then the temp drops below freezing.
I imagine you don’t see this problem much in Arizona, but I figure the oil helps keep the rubber soft.
The same process with whatever you use to condition your TIRES would probably help also.
Put a few drops on a paper towel and wipe over the seals.
Shawn S
Old 08-14-2002, 01:06 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
303 Aerospace Protectant. Hs UV protection and works great. Use it on all my weatherstripping.
Old 08-14-2002, 01:22 PM
gsrblack's Avatar
Where can I buy 303 Aerospace Protectant? At the local car parts store?
Old 08-14-2002, 01:25 PM
Xe- For Better Hwy Vision
xenon7's Avatar
Only you man!! To get a hold of such a product.
Shawn has the right idea, just keep the seal from drying
out thats all.
Old 08-14-2002, 01:36 PM
JasonT's Avatar
I use a little WD-40 on a rag, once a year.
Old 08-14-2002, 01:39 PM
xenon7's Avatar
I would be cautious about using that, petrolium based products and rubber do not play nice together.
Old 08-14-2002, 02:44 PM
Where is my super sauce?
Slimey's Avatar
I also use the 303 Protectant. You can buy it through Performance Products. You can also get it at various boat stores (West Marine, I think). Prior to that I used the Zaino tire dressing. I also use it to clean/treat my hoses in the engine bay.
SharksBreath
12-07-2012 11:18 AM
ABP_04TL
09-09-2012 05:52 PM
negan1
12-23-2008 02:36 PM
Philmatic
02-26-2008 02:38 PM
tirekicker42
05-19-2007 10:59 AM
Quick Reply: Keep weatherstripping from cracking/discoloring?
