Keep weatherstripping from cracking/discoloring?
Old Aug 14, 2002 | 11:46 AM
gsrblack's Avatar
Is there anything I can put on weatherstripping to keep it from cracking or turning white in the sun? My friend's 2001 TL is doing it already and I don't want to see my '03 CL-S doing that in the near future...
Old Aug 14, 2002 | 11:48 AM
KavexTrax's Avatar
the early 01's may have that problem but older '01s are fine (aug-sep01 and older).
You may want to see your dealer for a fix.
Old Aug 14, 2002 | 12:15 PM
Shawn S's Avatar
I don’t know about CRACKING, but I always wipe a light coat of Johnson’s Baby Oil on the door gaskets in the fall.
This keeps the doors from freezing shut in the winter if it rains and then the temp drops below freezing.
I imagine you don’t see this problem much in Arizona, but I figure the oil helps keep the rubber soft.
The same process with whatever you use to condition your TIRES would probably help also.
Put a few drops on a paper towel and wipe over the seals.
Shawn S
Old Aug 14, 2002 | 01:06 PM
NSXNEXT's Avatar
303 Aerospace Protectant. Hs UV protection and works great. Use it on all my weatherstripping.
Old Aug 14, 2002 | 01:22 PM
gsrblack's Avatar
Where can I buy 303 Aerospace Protectant? At the local car parts store?
Old Aug 14, 2002 | 01:25 PM
xenon7's Avatar
Xe- For Better Hwy Vision
Only you man!! To get a hold of such a product.
Shawn has the right idea, just keep the seal from drying
out thats all.
Old Aug 14, 2002 | 01:36 PM
JasonT's Avatar
I use a little WD-40 on a rag, once a year.
Old Aug 14, 2002 | 01:39 PM
xenon7's Avatar
I would be cautious about using that, petrolium based products and rubber do not play nice together.
Old Aug 14, 2002 | 02:44 PM
Slimey's Avatar
Where is my super sauce?
I also use the 303 Protectant. You can buy it through Performance Products. You can also get it at various boat stores (West Marine, I think). Prior to that I used the Zaino tire dressing. I also use it to clean/treat my hoses in the engine bay.
SharksBreath
Dec 7, 2012 11:18 AM
ABP_04TL
Sep 9, 2012 05:52 PM
negan1
Dec 23, 2008 02:36 PM
Philmatic
Feb 26, 2008 02:38 PM
tirekicker42
May 19, 2007 10:59 AM
