K&N Drop in filter
Old Oct 26, 2008 | 10:09 PM
immauser's Avatar
Registered Abuser
K&N Drop in filter
Ive searched everywhere for this and didnt seem to have an actual picture of the k&n in someones car.... i saw on some guys tl, they didnt have the top on the air filter? So if i got the K&N, do I just bolt it on and not put back the cover/lid of the filter box?? thanks in advanced
Old Oct 26, 2008 | 10:28 PM
CL-Slick's Avatar
Chillin' in my trailer
The drop in filter fits directly into the stock air box. My brother had one in his old TL. They have them at AutoZone for around $60 I think.
Old Oct 26, 2008 | 10:36 PM
immauser's Avatar
Registered Abuser
wow....thats as much as the ebay CAI......i like the sound...but alot of people are saying the cai are way too loud... so im debating between getting the k&n or getting the ebay cai.....
Old Oct 27, 2008 | 05:19 PM
CL-Slick's Avatar
I like the sound of mine. I'll try to take a decent video with sound of the CAI and not so much the exhaust. You get more hp from a CAI though.
Old Oct 27, 2008 | 06:01 PM
typeR's Avatar
remove the lower resonator and ull probally get 8 hp instead of 10 , and have a nice deep sound
Old Oct 27, 2008 | 08:58 PM
CL6's Avatar
CL6
My only car is a Bus
Doesn't it add like 17 whp?
Old Oct 27, 2008 | 09:43 PM
TheWeez's Avatar
I Wanna Beer
It can be really hard to get it in there and get a good seal. The paper filters are tapered on the side closest to the engine which makes it easy to put in. The F&N filter is the same thickness all the way around and it can make it hard to get the engine side pins locked through the holes while maintaining a good seal. Mine started leaking after a couple months because the seal wasn't quite right and was making a humming sound at idle.
Old Oct 28, 2008 | 01:47 AM
nf3d0149ab's Avatar
What does...CAI?
Joking right?
Old Oct 28, 2008 | 03:09 AM
rp_guy's Avatar
'03 ABP YA4-S 6MT
... serious?
like typeR said, at most 10whp even with a cai
Old Oct 28, 2008 | 10:37 AM
immauser's Avatar
Registered Abuser
wow urs started leaking? i never heard that happen to anyone....
Old Oct 28, 2008 | 11:13 AM
civicdrivr's Avatar
I didn't have the issues that TheWeez had. My Icebox was on backorder so I picked up a K&N. Two days later the Icebox came in the mail. My K&N was used for about a week if your interested in it.
Old Oct 28, 2008 | 11:24 AM
02CLNOS's Avatar
I have the k&n filter and its ok, kinda loud if you what type-r said. But i built a 4" intake that is kinda cold air. I had the cold air and i found it to be pulling up moisture into the pipe.
Old Oct 28, 2008 | 12:50 PM
cbusAcuracls's Avatar
I have the K&N drop in filter in my stock box with the lower res. removed. 10x better and sounds deeper.
When I removed the lower resonator box I kept the rubber seal in the bottom of the box and attached a apox. 6" x 8" .032 alum sheet metal shield rolled 3/4the way around that lower hole. This is attached to the rubber seal which is firmly secures to the bottom of the stock air box. If you can picture it its almost like a 6" tube that pulls cold air from the lower fender of the front of the car but the shield actually blocks any moisture that might come up from the bottom of the car in case its pouring or I drive through a puddle.
I studied comptech's ice box design and pretty much used the same principles they did in designing their ice box. Google search Comptech Ice box pic to get an idea what I'm talking about.
I've had it in there for over a year and I have washed and oiled my K&N filter 2 times since and for the money and power it is def. the easiest and best sounding intake. Plus the fact it looks completely stock from the engine bay.
P.S. I've had no problems with the seal on the K&N filter in the stock box. Just make sure you install in right and there will be no problems.
immauser's Avatar
Registered Abuser
02clnos...no leaks at all so far?
Old Oct 28, 2008 | 12:54 PM
immauser's Avatar
Registered Abuser
cbus, u dont have the pic of ur setup by anychance? it soudns interesting but the tubing / sheet metal part was confusing.... and do u think the filters make a sound diff.. oem vs k&n? some people say filters dont make a diff?
Old Oct 28, 2008 | 01:14 PM
I knew someone was going to ask for it...ha. Sorry no I don't have a picture handy. I will try to take a picture soon. I need to change my oil in the next couple days so I will try to take a pic then.
The only reason I think my set up sounds different (deeper growl) is because of the lower resonator box is removed.
Here is a pic of the Comptech ice box. Mine looks similiar to this..but with just a alum tube bottom instead of the black tube shown...
Here is a Stock Air Box w/ lower resonator taken apart (this is not mine..I google searched this pic)
To the right you will see the stock filter inside top of the stock airbox. In the middle you will see the bottom of the stock airbox (its upside down in the pic). That hole w/ rubber seal is where I have the alum. attached. Then finally to the far left is the stock lower resonator (this is to be removed completely). Does this kinda make sense what I'm talking about?
Hope this helps.
Old Oct 28, 2008 | 01:33 PM
immauser's Avatar
Registered Abuser
yea it helps cbus, thanks.... i removed my resonator already, not too much of a big diff with sound..will k&n make a diff?
Old Oct 28, 2008 | 01:37 PM
Oh yea..mine did only when you really get on it though. K&N breathes alot better.
I had a AEM CAI on before this and this set up is alot better. Cold air and a good filter is the key.
Old Oct 28, 2008 | 01:39 PM
immauser's Avatar
Registered Abuser
ah..ok .... so the filter will make a diff... i just took off the resonator so far and will change to k&n soon.
any speed diff?
Old Oct 28, 2008 | 01:47 PM
Since you have the resonator removed already...the hp difference between the stock filter and K&N will prob. only be only 1-2 hp. I personally can tell a difference if I get on the throttle 3/4 of the way cruising about 20 mph.
It just seems like the K&N breathes better and the car pulls harder/longer.
Old Oct 28, 2008 | 02:09 PM
02CLNOS's Avatar
nope. This is what i have made... it just fits.
I had to cut out the engine cover to fit the pipe but i painter the clamp black so you can't see it
I plan on making a box around it and make a scoop in the fender for a ram air. I'v seen a VW with a side mounted scoop but i'll mold mine into the fender
Old Oct 28, 2008 | 02:12 PM
immauser's Avatar
Registered Abuser
wow, thats like a short ram?
i was talking about just the drop in k&n filter in the stock box, i thought u had that
Old Oct 28, 2008 | 02:18 PM
02CLNOS's Avatar
short and sweet! I just took the oem setup off and did this, but i never had any leeks with the k&n
Old Oct 28, 2008 | 02:34 PM
immauser's Avatar
Registered Abuser
oh ok, i might have misread because i thought u had a leak with k&n
Old Nov 7, 2008 | 07:14 PM
BLUFFMEEH112's Avatar
5th Gear
i made a short ram for my 03CL-S, ill post pics tomorrow.. but does yours make this loud vaccuum sound? like really loud woooooooowing sound, i can hear it parked outside from my room. comes straight fromt he tube. im thinking its because the tube is too thin maybe??
Old Nov 8, 2008 | 05:26 PM
02CLNOS's Avatar
mine does that to, when i'm at a light people just star at the front of the car than at me... shortly after they roll up their window. Also it whistle's when i'm about haf throttle.
Old Nov 10, 2008 | 07:05 PM
immauser's Avatar
Registered Abuser
sounds clean tho
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
4drviper
Sep 23, 2015 07:42 PM
