just installed comptech headers and car now runs weak!!??
Old Oct 28, 2007 | 11:26 PM
cl8trr's Avatar
what the hell is going on here? this is my 3rd cls-6 and I have never had this problem before,I have owned comptech and XS headers and never had this problem. car does not accelerate as it should! any ideas? not throwing any codes and exhaust is leak free!
Old Oct 29, 2007 | 01:35 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Reset the ECU and try again. Does it feel weak in general or just some parts of the powerband? Try seafoaming the car to see if there are any leaks visually, helps me.
O2 sensors all plugged and screwed in properly? Put back all the vacuum lines? The left vacuum line on the IM fittings if disconnected will leave you without CC but who knows what else can be left hanging.
Do you have time tomorrow for me to check out the car?
Old Oct 29, 2007 | 01:36 AM
sinfulj32's Avatar
give it some time for the ecu to adjust? my car felt shitty slow the first time i slapped my headers on. give it a little while and see how it turns out.
Old Oct 29, 2007 | 01:40 AM
Weird, I never had this problem just as Mike said for himself earlier, seems like you would feel something at least maybe not the max potential at first but I don't see how it would run shitty rght after install.
Old Oct 29, 2007 | 02:59 AM
Corrosion's Avatar
White as night.
Maybe they're leaking?
Old Oct 29, 2007 | 06:11 AM
INSPIRE 32V's Avatar
Glacier Frost Mica CL-S
hope u figure it out
Old Oct 29, 2007 | 09:50 AM
underst8's Avatar
140,000 miles young
quick ecu reset - unhook bat, let sit a few, then hook it back up and start her up with no aux. electronics on. Don't touch the throttle for 10 mins just let her idle. Hopefully that solves your problem. Does sound strange.
Old Oct 29, 2007 | 09:58 AM
cl8trr's Avatar
oh man, checked everything.. nothing is loose, just seafoamed the bit** inside and out,(vaccum-tank-eng) still running weak? the headers are brand new and I had them installed at acura of cerritos? I need to go pick up my old ones today(yes they kept them even though I specifically asked for the old ones to be put in the trunk).. im gonna go use different gas and octane booster,maybe bad gas?imrc?
Old Oct 29, 2007 | 11:00 AM
different gas??? were you not using 92/93 octane already
Old Oct 29, 2007 | 12:08 PM
sinfulj32's Avatar
drive it around and put like 50 miles on it. most likely the characteristics of your power will change. if it does not change after a while of driving, you will know for sure something isnt right. even if it doesnt change than you probably will at least get a better idea of whats wrong after driving that much. go cruise around and kill like a 3rd of a tank and let us know
Old Oct 29, 2007 | 12:12 PM
AuCLSman's Avatar
main O2 sensor is possible culprit, damage may have happened during header install.
check sensor wiring for ground fault, however it should show code if malfunctioning.
Old Oct 29, 2007 | 12:30 PM
SIRSIG's Avatar
THE J35A2...
get it tuned! h/i/e/pipes gives you hp but not torque... well, maybe a bit...
Old Oct 30, 2007 | 12:40 AM
Mike just let me know if yu want we can check it out. Should be relatively easy to figure out to someone from an outside perspective.
Old Oct 30, 2007 | 12:50 AM
gc86's Avatar
Advance
I'd inspect the main o2 sensor.
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
NSolace
Sep 3, 2015 08:02 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
