Just Bought OptionRacing Pulley
I Blaze Up In
So I just bought their underdrive crank pulley off their ebay store for $25. I also picked up both Gates belts off Amazon for $30, i gotta say $55 for a pulley and both belts is a great deal. Im just waiting for them to come in and when I install it i'll do a D.I.Y for you guys, since I noticed there isnt a crank pulley D.I.Y for the 2nd gen.
I'll update you guys as soon as they come in
-Mark
-Mark
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I would LOVE a DIY on installing the option pulley and belts. My pulley came in the mail today and will try to find Gates belt locally at like pep boys or Strouss auto. Im having a tech help me but never did pulley so a DIY with some pics would be a great help..
Alot of peeps are going with this pulley latley I HOPE i notice a difference.
I Blaze Up In
^^ Its not really needed for most cuz it is pretty simple and straight forward. But alot of members might need help with it so I figured I might as well snap a few pics while im installing it and make a DIY for Azine.
Im hoping to get this done next wednesday, the belts should be in this friday but the pulley isnt getting here till early next week.
-Mark
-Mark
-Mark
-Mark
CL-S 6Speed is rarely in
I Blaze Up In
-Mark
Well breaking off the nut isnt hard with the right tool, a 3/4" air gun (which is wut i'll be using) will pop that sucker off. If you dont have access to an air gun you can use a big breaker bar and slide a pipe over the handle for extra leverage, which = extra torque and put your weight on it and it should come off, and dont forget to soak it in some PB blaster penetrating oil to help the nut come off. As for torquing the nut, you just need a torque wrench set to 180 lb-ft
-Mark
-Mark
I Blaze Up In
Well 150 should be fine, they recommend 181 lb-ft on UR's website but I dont think there should be anything wrong with torquing it to 150.
-Mark
-Mark
I Blaze Up In
I Blaze Up In
If your car is auto, you put a prybar or small crowbar in the teeth of your flywheel that you get to via a small access panel under your tranny and it will keep the crank from spinning. If your 6spd, you have someone put it into 6th gear and step on the brake(while the car is off) and it will keep the crank from moving while you take the nut off.
-Mark
-Mark
-Mark
-Mark
how do you get the drive belts off?
B A N N E D
Why is it easier to do on a 6 speed cuz mine is auto and im prob gonna get it done tommorrow.
2fast4you where u able to find the belts u needed at a local store cuz tommorrow is the only time the techs have time to do it and i have to pick up the belts locally at like strouss or r and s or pepboys./
I Blaze Up In
Or you can spend like $60 and buy the special honda crank nut tool that holds it in place while you take the nut off. But I dont think its worth the money, especially since it only works when your taking the stock pulley off and not when putting the aftermarket pulley on.
As for the belts, your gonna need Gates K060441 and Gates K040425 (if you have the underdrive pulley). They dont need to be gates, but you can take those two numbers I gave you to an auto parts store and they can translate the numbers for you to another brand like Goodyear Gatorbacks and they'll be the same size.
B A N N E D
I got the sizes of the belts for anyone else that needs them..
Power steering = K040425 (gates) or 43 1/8" ( 1095mm )
Alternater = K060441 (gates) or 44 5/8" ( 1135mm )
I'm sure it's simple after the fact like changing rotors and pads. But the first time you do anything it's gonna be awkward if you're not familiar. It also seems like a few people have bought the pulley recently so a DIY with pictures for reference is perfect timing so a big
to the OP. Knowledge is power.
i also recently got the option pulley and gates belts. i will be trying bigmark's method of holding the crank pulley in place on my auto cl. i don't even have a breaker bar or torque wrench (do i need a really long torque wrench? i'm leaning towards just getting a small one) and will be getting both soon. can't wait to install...
Whats up with RDX owners?
The easiest way I find to break the crank pulley bolt loose is to put a breaker bar on it and have the end on the ground. Then pulse the starter a few times. Much quicker.
I Blaze Up In
My favorite way is to put a breaker bar on the nut and have the handle angled to the bottom right. Then you put a jack under the very base of the breaker bar handle and slowly jack it up while you lower the car at the same time and you'll either A.) Get the nut off, or B.) Break your breaker bar, its also kinda a last resort method but its worked for me in the past.
-Mark
Yea, but that takes mega balls of steel to do confidently. Ive done a few crank pulleys before and ive never had to use that method. I think the starter method is like a last resort when all else fails, but ive always been able to get it off other ways.
-Mark
-Mark
Dumb question .. what does this offer, especially the belts, versus OEM?? Rev faster? Is it worth doing for an auto?? About to have timing belt, water pump, etc changed out and if this mod is worth doing, it would be perfect timing (no pun intended)!!
Yes its worth it. The car is much more responsive and it frees up some power.
My cp bolt was on there pretty damn tight. I bought the crank pulley tool and that did work. I tried my impact wrench, no dice. The starter was the last resort, and it worked.
B A N N E D
Do u guys know what fuse or fuses I have to pull to have the car crank but not start to have the motor do all the work? Which fuses and are they in the car or in the engin compartment? The exact fuses..Thank u!
Fuel pump fuse. Just do it the awesome way and crank that bitch a few times.
Seriously though, don't hit it like your trying to start the car. A quick pulse. Really quick. A few of them usually does it.
Don't know. I didn't pull it. Ill check the manual when I get home.
B A N N E D
Is it in the owners manual cuz im gonna go to the shop right now to try and do this!
let me know if u find it , I will check here in 45 min when i get to the shop!
I wont be home until 5 or so. The owners manual may have it. The fuse panel lid may even say it.
Power steering pump has a tensioner bolt on the top. Turn that out and it should loosen. If it doesnt move, the two nuts holding the pump to the bracket are probably really tight, so loosen them as well, they are on the bottom of the pump. You need to remove part of the engine mount bracket to get that belt out.
The alternator/a/c compressor belt has a tensioner on it. Take a 14mm (I think) wrench and put it on the bolt that is in the center of the tensioner. Turn it like you are loosening it. Slide the belt out. The tensioner is spring loaded, so let it back down easily.
Sorry Mark if I am jacking your thread.
