Jump Starting Question
In have one of those portable jumpstarters, it's like a yellow box with a handle, little voltage meter on it, and the black and red cables w/clips. How can I tell if it works? If I don't have a car I need to jumpstart, is there anyway to tell? Thanks...
Unregistered Member
The only way to really tell is to put a load tester on it. You know, the kind for automotive batteries (which is basically what your jump starter box is anyway) that checks the available amperage for 10-15 seconds.
In general, if a fully charged box (12.4 volts or more) should not drop below 10 amps under load for 10-15 seconds. If your jumpbox passes that simple test, then it's fine.
I've got that exact same portable jump start system. I believe mine is made by Everready. Dunno have to check.
But I will tell u this, u charge up that portable jumper and ur set to go....for about 15 sec. If u have a stubborn car that won't start for the 1st couple of seconds ur FKed. U hook that jumper to a car, u better hope that with in 5 secs of turning the engine that the SOB had better start. Cause if not it takes 72 hours to charg it back up!!! I was shocked when I read it in the manual. But when I had that exact same incident happen to my mother's car it was over. The engine is a I6. Not a very big engine. But that portable POS turned the car for no more than 5 sec. It had to be because the engine required so much cranking power. I mean the car's battery looked like two of ours fussed together.
In the end I tried jump starting the car with my CLS. But to no avail, our cars are just not good at jumping larger engines; even when u rev the CLS to 3K. Ended up having to call my friend with his duely to come and give me a jump.
But my conclusion to this story is; yea its a great little paper weight that works in jumping decent working cars that ONLY need a SIMPLE jump.
Oh and the cool thing about my jumper is that it has 2 cigaret lighter sockets. So I can charge my cell with a car charger, away from home, and away from the car.
Juker008
Juker008
Unregistered Member
Originally posted by KCPreki11
Tom, where can I find a load tester? Gas Station?
Juker008,
I also have a jumpbox, but it's capable of jumping at least 20 cars in a row before having to be recharged.
Not all of them are pieces of shit. I guess you get what you pay for.....
I paid $70 for mine. In reguards to jumping 20 cars. I really don't think I can even get to 12.
Let me ask u this; how long does it take to fully charge the jumperbox? Mine takes close to 72 hours. And I think that is total BS.
By the way what jumperbox do u have?
Juker008
Juker008
Unregistered Member
Juker008,
Even if you could get 10 cars started without recharging, that's pretty decent. But judging by your first post, it sounded like you couldn't even jump 1 car if it didn't start right away.
I'd have to go look at the brand name of my jumpbox (I don't remember off hand), but it costs about $150 and fully recharges in 3 hours. It's not an industrial unit, but it is far better than some of the cheaper ones you see in most stores.
Originally posted by Tom2
Juker008,
Juker008,
Yes if I can't jump a car a car in the 1st few seconds then the jumper box is dead.
I will say that it is a great little tool for someone who simply left their lights on.
Juker008
cycdaniel
12-17-2019 10:58 AM
