J32a2 Nitrous???......
3.7L Nitrous Breathing CL
Get the zex dry kit it does everything for you.
No need to adjust seprate seilnoids.you put jets in and thats it once it's programed.Also start at the 65 shot.
I sprayed it back to back,light to light till it was gone and no issue's.
The 65shot will probally be about 50hp.
this is new.
http://cgi.ebay.com/ebaymotors/ZEX-8...Q5fAccessories
Start looking into putting one together. here's one I found real quick.http://cgi.ebay.com/ebaymotors/Zex-D...Q5fAccessories Ask him if it has the nossle and jets.
It looks like it has the long line and the short line atleast.If it dont have nossel and jets you can get both for about 15 bucks or so.Then you will have a kit. fill the bottle and have fun for cheap dough.
this is new.
Whats up with RDX owners?
in a nut shell:
1)dry shot is pure N20 from the bottle w/ no additional fuel
2)wet shot runs a second fuel delivery solenoid (most times from the fuel line) to mix w/ the n20 as it goes into the intake
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
50 shot is nothing, u should be fine
dry shot is wayyy easier to set up, for the wet you have to tap the fuel line and run a second solenoid. worst car i ever set up was an IS350 (fucking spaceship) but in my experience, wet shot is better performing, and better for the motor.
2600lb CL
125 wet shot for about 4-5 yrs? On my 3.0 and on this 3.5
You don't even need a tune. Just colder plugs and high octane gas to help prevent for detonation (i'm running 1 degree cooler, but 116 octane alcohol). Don't use it in overdrive gears either. Don't abuse it. Do that, and you'll be just fine.
2600lb CL
Just want to add something for the OP, if you tune it just remember you don't run the car on nitrous 24/7. Therefore you have to get something that would allow you to have 2 fuel maps, 1 on the bottle and 1 off the bottle.
