It's time to replace the rotors and pads on the CL-S... suggestions?
if you want "performance" brakes i have no suggestions.
if you want stock peformance but a more durable brake pad try NAPA. they make 2 grades of stock replacement pads. i think the better pads are called NAPA GOLD. i've used them on several daily drivers. they hold up well, aren't too over-priced (although i've never priced Acura replacement pads), perform as well or better than the stock pads, don't fade any more than the stock pads, and don't squeel.
good luck.
good luck.
Start with the rotors and get the slotted. Cross-drilled, from what I've heard and read, have a tendency to crack prematurely. I like the stock pads, not a lot of brake dust. If you want a firmer feel on the brake pedal, get some stainless steel braided lines.
Originally posted by me_big_head_229
rotora make front and back slotted rotors
this seems like a good site. http://www.nationalfleetparts.com/sp_performance.asp
I have heard and read bad things about cross-drilled and slotted rotors. The brake article on team integra seems to do a good job explaining why not to go with them. In short slotted and cross-drilled rotors are kind of a thing of the past. There main purpose is to relieve gasses given off from the pads, however with improved pad technology that gives off less gasses the risk of using a weaker slotted or cross-drilled rotor is not needed. Basically the best way to increase stopping power is to use a bigger blank rotor so has a larger surface area and cools faster. Couple this with a semimetal pad and you have a good setup going. This however is according to the article. Personally I have used powerstop cross-drilled rotors and never had a problem until I needed new pads and had to turn the rotors, that is when the slight shaking and pulsing happened. I vote Brembo blanks and some semimetal pads, just my $.02
Originally posted by Rock2534
I was thinking of getting the rotora slotted rotors, i recently had my rotors resurfaced for like the 3rd time i think, and they gave me new pads too. If i were to get the rotors now, I wouldn't need new pads right away would i?
A good slotted rotor (Rotora) and a ceramic based pad is the way to go (Axxis). If you want, change your brake fluid too. Full synthetic @ DOT 5.1 (NOT 5), Motul is the brand to look for.
I need new rotors/pads too and was contemplating Powerslot and axxis ultimates. I'm also thinking about the Brembo Blank option and the axxis ultimates. Anyone tried the second combo? The pads aren't too rough on the rotors are they?
Originally posted by NiteQwill
When replacing rotors, you MUST buy new pads. When replacing just pads, you can simply just turn/resurface rotors, but it is not recommended.
Originally posted by mrsteve
I wouldn't go more than 2 times resurfacing the rotors. I had mine replaced the 3rd time they were warped.
I explained to the dealer than resurfacing the rotors over and over again will ruin the rotors and will not solve the problem. I asked them to replace the rotors and pads and they did.
I have 18K on these rotors/pads and I only get slight vibrations after some "spirited driving"
I warped my other sets every 7-8k before.
Here are some brake improvement options:
1) Change to aftermarket pads. This is the least expensive option, but will improve braking somewhat. CompTech sells Metal Master and R4S pads. But there a lots more out on the market that are as good.
2) Option 1) and change out your OEM rotors with crossed drilled and/or slotted rotors.
3) Change to SS brake lines and replace your brake fluid with a better fluid like Motul 600.
4) Big brake kit like Rotora or Brembo.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
