It's my turn for Tranny failure. What to do?
My tranny has been acting up lately then today I barely made it home from work. Erratic shifting, extreme slippage, high RPM's. Before I attempt to drive it either to the dealer or repair shop I'd like to know my options because chances are it won't make it and I'll have to get towed. It's a 2001 CLS with only 55K miles. So as far as warranty I'm outside the time limit but well within the miles. Should I first call the dealer or call Honda to see if they will provide any goodwill consideration? I figure if they pay at least half I'll get it done at the dealer. I just don't want to bring the car to the dealer and find out it'll will cost 5k and then have to get it towed somewhere else. But will they talk with me with out even looking at the car? Confused as what to do.
To many cars in my garage
Wierd how some trannys go mine been getting worse and worse bit I keep driving it ( its been a year )
I would call and try to get it fixed for free If its free its worth a try
but when mine goes Im getting the 07 tl/05 Odossey tranny intsalled Probably cost 2-3k but never have to worrie again IMO
I Drive Like A Dick 8≈
ummm ask P. Diddy he was first to do it, or nva-av6 (he did it) and from what I've read its not that much more work on top of swapping out the tranny itself
https://acurazine.com/forums/2g-cl-problems-fixes-70/another-solution-my-auto-cl-guys-758220/
heres the link
heres the link
No dash lights on
That's the problem. The only time I use the Dealer is for warranty issues so I don't think he will do much for me. That's why I was thinking about calling Honda direct. But they probably won't talk to me unless I bring it to the Dealer first.
lowrd on tein CS biatch
my car's entire life was at the dlr b4 my trans went and they wouldn't do shit for me and i KNEW the manager!!!!! fuckers
i got my trans built on the side by my buddy who's a master acura tech. for 1900 so i got lucky. saved myself 2500.
but if it goes again i will go do the 07-08 TL tranns. but she's running real strong right now
Called Acura and they were no help at all. Said I needed to take it to the Dealer and work it out with them first and if I wasn't satisfied to call them back. They also said it's a case by case basis and there are no guaranties of getting a price reduction. So since I have no past relationship with the dealer I'll be taking it to a local repair shop that was recommended to me.
Look, go/call the dealer and talk to them as nice as possible and hopefully they will be gracious enough to at least cover most of the cost if not all(should have been able to tell you when you contacted them if it was covered). For the tranny I would only take it to Acura. If that doesn't work out, then go to your local recomended repair shop. Good luck
I recall in the thread they said the 08 TL transmissions won't work, and only half the transmissions from 07 will work. Basically anything 04-06, and some 07 TL's will work. 04-06 Odyssey transmissions work.
If I do the swap, I'll more than likely just get a 05 Odyssey trans
If your not the original, check the service records and see if the transmission was replaced before. If it was, it might still be a warranty on that specific transmission.
I don't know why you guys keep saying 3-4k for a tranny replacement. I was quoted 5900 for a new tranny.
I believe its outta the acura warranty time range because I heard that was supposed to be 7 years 108k miles, something like that.
But you can take it to a transmission shop and see if anything can be replaced. Dealerships only replace the transmission, they don't repair anything. When my tranny went, I took it to Amcco and they said it might be something minor that can be replaced and it would save a few thousand. I only said that cuz u said there was no lights on your dash.
But try with the dealership first and see if they will work with you.
Look, go/call the dealer and talk to them as nice as possible and hopefully they will be gracious enough to at least cover most of the cost if not all(should have been able to tell you when you contacted them if it was covered). For the tranny I would only take it to Acura. If that doesn't work out, then go to your local recomended repair shop. Good luck![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Yes it is past the time limit but way under the miles which is why I thought I'd get some consideration from Acura. A properly maintained transmission should not fail at 55K.
IMHO
Acura wants nothing to do with us 2nd Gen CL/TL transmission anymore.
They are probably doing the happy dance now that ALL of their extended warranties have expired so now they aren't obligated to do jack.
For w/e it's worth, get your tranny rebuilt and you'll save the most $.
i pulled through with only a 1900 bill. new gears, trans star tq converter, new low hold gear, and front trans mount all included.
So there is hope.
5900 for a tranny lol I would have bought a new car if that was the only option
So there is hope.
damn only 55k miles for a 01 thats crazy. Sorrry about ur tranny issue. If Acura would cover it have them do it, otherwise skip dealer. There is a new thread from p.diddy about replacing thetranny with one from a newer tl or the odyssey tranny. I think that is the best option. If you replace with the CL tranny it is likely to fail again.
https://acurazine.com/forums/showthread.php?t=758220
The only time I go to dealers are for issues under warranty and to buy cars. When I go to get something fixed under warranty they always try to get me to service my car there and I kind of feel unwanted when I decline. I've changed the tranny fluid myself more times than required by the manual. Unfortunately I don't have the receipts to prove it. I just don't see any incentive for the dealer to help me. That is why I'm extremely disappointed with Acura when I called them and got no help. If they at least assured me that they would split the cost at a minimum then I would have taken it to the dealer. I'll be taking it to a local shop that was recommended to me on Monday. They have experience doing Acura's. I figure even if it needs a complete rebuild it will still be a lot cheaper than the dealer.
Connecticut. I'll ask the mechanic about the alternatives. I just don't want this to drag out. Also, if they put in a different transmission they probably won't warranty it. I'm just looking to get another year out of the car so a rebuild should be fine.
09 TL SH-AWD
Looks like I'll be joining the fail club soon... I hate my car right now, did not plan for it. And it was so good to me for the last 5 years, only minor issues and mods...
I got a guy that will rebuild ur trans for under 2K Guaranteed no matter how screwed the gears are.
Mine were melted, and my o/d gear was messed also, so i got new gears, o/d gear, front trans mount, filters, trans star tq converter, switches cleaned.. all for 1900
PM me if you wanna do it through my guy you'll save a fortune as I did.
I just had another guy mssg me but he was in a rush so he's getting his trans built at mr.transmission and they are charging him 3600!!!!! plus tax.
7th Gear
Getting my tranny done by your man. Should run around 1800-1900 including front mount. Got a quote over the phone from Acura in Burlington $6,400 plus taxes, crazy.
Thanks for the great lead on the mechanic.
09 TL SH-AWD
That makes me think that these prices depend on certain individuals running those places. Shouldn't it be at least somewhat similar? I wonder how that person would react when you tell him you got a quote $2000 less at another Acura dealer. That's just fucked and a huge rip off, plus those remanufactured trannies fail even faster than original sometimes. With those prices people are better off getting a new car.
HeloDown
09-08-2015 06:51 PM
