Issue while idling
Old Mar 19, 2009 | 10:14 AM
Brittonj85's Avatar
Issue while idling
I am having this weird issue with my car while idling. I notice the other day while I was at the car wash cleaning my carpets. I notice that when the fan comes on, my audio system and head unit would cut off and then cut back on. I also notice that the VSA and maintenance light would flash too. Has anyone experience this issue before and if so what should I do?
I thought it was something wrong with my oil so I had my oil change, filter and even drop in some Royal Purple and drove on my married way. A couple days after it happens again so it wasn't the oil. Should I flush out my coolant system and change my filter? It's been eight months sense I changed the filter.
What should I do?
Old Mar 19, 2009 | 10:48 AM
2Fast4you's Avatar
almost sounds like it might be the battery any trouble starting in the morning?
Old Mar 19, 2009 | 11:31 AM
Brittonj85's Avatar
I have ran into a issue where I would walk up to my car and notice that the clock and alarm light would be turned off. So I would pop my hood and disconnect the battery and then reconnect the battery. But I thought that was a normal problem with cold weather.
I am going to see if Pep Boys can test my battery to see if the cells are ''on their way out the door''. I think they do battery testing for free.
Old Mar 19, 2009 | 06:25 PM
aznboi2424's Avatar
something is wrong with your electrical system. doing a oil change or anything to your cooling system will not do anything to solve the problem. try the battery first, then maybe test your alternator or it maybe a broken ground.
Old Mar 19, 2009 | 06:29 PM
AnthraciteBeast's Avatar
Old Mar 20, 2009 | 01:46 PM
Brittonj85's Avatar
Cool I will test both of them.
Quick question, does everyone clock stay on?
Old Mar 20, 2009 | 03:43 PM
fsttyms1's Avatar
Why would you think that it was something with your oil??
Its an electrical issue. Have your battery load tested, test your alt output, and check the battery grounds.
Old Mar 20, 2009 | 07:59 PM
aznboi2424's Avatar
lol thats what i was thinking and he was gonna flush his coolant next!
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
