intermittent 2nd gear grind... anyone?
hey guys
I've been running on fresh rebuilt cl-s trans for about 8k miles.
The grind has happened a few times from first to second, but it went away the first time it happened (maybe 3-4 months ago).
It recently started happening again. It really only happens when I get on the car from 1st to 2nd. The last time it happened, I tried to replicate it, but I could not get it to grind no matter what.
Is this normal? Could my busted motor mounts be causing this?
Ultra Negro
hey guys
I sense synchros, or cold tranny, or maybe possibly low tranny fluid.
I got the Shifts
push your clutch pedal ALL the way down during wot shifts. this is caused by the synchros no speeding down quick enough for you to jam it into second.
by depressing the clutch fully, you engage this process in a less harsh manner.
also, let off the gas BEFORE entering the clutch.
i used to do it too, takes practice
Whats up with RDX owners?
Mine does it when I rev up to around 6k in first and granny shift to second (like in slow moving traffic). Its annoying.
What fluid are you running? Im switching to GM synchromesh soon.
I dont think its my shifting because I can go WOT and slam gears without a grind. Its only these slow speed grinds that I have.
B A N N E D
as said it almost sounds like it is driver induced error, of not fully disengaging the clutch before shifting (also make sure the floor mat is not blocking the pedal from fully going down, there is a reason for that hook on the floor mat right in front of the seat, to help prevent the mat from slidding foward)
Back to a MT!
My car did this when I first got it and only when I was shifting as quick as I could... probably was still learning the timing of clutch disengagement and shifting... I figured it would have only gotten worse, but with 144k on the original clutch its been fine...
Thinking back, I think I may have had the grind a few times when shifting slow as civicdrivr said, but then again... not sure why you would want to be sucking that much gas in slow moving traffic. I usually shift around 2.5k during normal slow driving, saves more gas.
In most of the traffic I drive in, shifting to second is pointless. The second you do it, we come to a stop again.
But when I am at 5-6k rpms and I shift to second, its in the city doing around 20mph. For some reason I actually get better gas mileage if I slowly ring it out compared to shifting as low as possible and putting un-needed load on the motor.
I got the Shifts
its 90% driver induced. maybe 10% due to improper pressure plate engagement and disengagement.
gm synchromesh also helps with the syncho smoothness and takes out the notchiness that our trans have.
to say that there is something wrong with a honda designed manual gearbox is like slapping your mom on mothers day.
these things win awards
Lol well said, but my issue hasn't been here since I bought the car. And it doesn't happen when I drive other cars, and I can replicate it.
hey guys
https://acurazine.com/forums/2g-cl-2001-2003-50/clutch-damper-bypass-cls-6-a-483022/
I get it too... When I first bought the car and did a WOT into second I grind EVERY TIME!!!! and I started slowing my shifts down a little bit and I don't grind at all... it's mainly a driver thing I think.
i never installed the clutch dampener.
im running penzoil syncromesh, the stuff that comes in a yellow jug.
i havent changed my fluid since the swap, i may do that this summer. i remember the tranny was soo smooth when i had fresh fluid in it.
i hope its driver error, if not, i would rather replace the 2nd gear syncro when i pull the motor soon.
anyways, thanks for all the replies.
I got the Shifts
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
guyvelella
09-30-2015 11:02 PM
RSpyder
09-30-2015 12:46 AM
