Intake Noise? Help!
Moderator Alumnus
squeiling similar to a hissing noise? Because that's what my AEM CAI does. The intake hisses because there is no noise damper like the OEM setup has. All you hear is raw air being drawn into the manifold. During cruising speeds I'm sure you've also experience the whistling the intake makes if you happen to speed up a little bit and let off the gas.
not so much as a hissing noise cause pretty much all intakes do that, except the oem and/or icebox. it sounds like the bypass valve might be bad or have a rip in it. it sounds exactly like a loose belt, but only at idle when reving or cruising its not there? Im clueless man and its starting to drive me crazy!
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
