Installed Eibach pro kit w/ KONIs
This weekend I installed the eibach springs with the KONI shocks. The car considerably lower. It feels lower when I drive, and when I get in or out of the car, it's much closer to the ground. The turns are much better, they feel a lot more sure. I didn't try to corner too hard or too fast, but it feels like it would handle a fast turn. I left the KONI settings at default, which I think is the softest level. It feels stiffer than stock, but not too much, only when you go over rail road, or very bumpy road that you feel the stiffness.
There is one problem however, that I need your guys' input. Whe I had 4 people in my car, the rear left side was kind of knocking on turns. Also, the car kind of felt too low. I am thinking about making the back shocks stiffer, but I am wondering if there is something else I should do. If anyone has this kind of suspension setup, let me know what you did. Thanks.
Othere than that, i would recommend this to everybody.
on bin laden
i have had that exact same setup for about two years now. the konis have an upper and lower perch setting. i set all four on the upper perch. the front is the perfect drop, the back is about 1 inch higher than i'd like it. i get no knocking or rubbing with 19x8 rims on 235/35/19 tires. i have the front struts set as stiff as possible, the rears about a half turn off of being all the way stiff. the car stay neutral in the hard corners on the track.
on bin laden
Originally posted by FPAEP
Mine are both at the highest perk, and the rear looks like it couldn't be any lower. Did you ride get too firm on the highest setting, or is it not too bad. I am trying to keep my ride as close to the stock softness wise.
I bought mine from someone from this board. they were brand new, and looked like they are from KONI. However, mine only had 2 perches. This is making wonder. I just think that the NEUSPEED and regular are just different shocks. i will post the picture tommorow.
the regulars have three perches part number for the regular koni yellow is as follows 8041-1258sp1 or sport...i have the SP3 you sohuld have the perch in the middle setting which is static then there should be one up and down from there....looking at koni's web site i think im wrong...it seems there's stock and lower ...rear lowers the car approx 15-20mm front 25mm... 25.4mm =1 inch...you should be on the top perch setting if you didnt want additional lowering over your eibach springs
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
