instaaled koni adj. shocks help
if its like a side to side vibration your feeling... its likely whoever installed your shocks, you or the shop, didnt torque your wheel lug nuts properly.
most common cause of steering wheel vibration.
Are you using the upper or lower perch on the Konis? I'm using the upper perch with Comptech springs. I noticed that after my car was lowered I got more feedback from the road through the steering wheel. I can also feel the vibration you speak of through the wheel at idle.
pick one
options:
a: lug nuts mis-torqued
b: alignment is hosed
c: something wasn't installed right on one of the konis, leaving it mounted slightly different than the other three
d: one of your tires is soft/flat/improperly worn
e: car is about to explode, eject eject
Take your car back to the shop. This vibration is NOT normal. I feel no vibration at idle and my Konis are 1/2 turn stiff. You will feel bumps in the road more due to increased suspension stiffness, but not steering wheel vibration.
Your install was munged. Tell the tech what you are feeling and they need to fix it.
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
