Innovative Mounts got it right this time!
I truly believe that they have worked out most of their issues in the past and I would recommend them any time.
I personally blame problems in the past with user error or the common do it yourself people, but I believe that it's just better to have them do it for you considering that you might not have all the tools available to install these mounts correctly with the positive alignment of the engine and body of the car.
disagree. the mounts fail due to the design and the poly. the dealership does not have any special protractor, plumb bob, laser or gizmo that aligns the motor. i believe you have the same innovative design that RUF has been running. i also know that a few people had their mounts installed by the "dealership gurus" and have had the same sagging mounts a few months later. i blame innovative for lack of R&D, not the DIY'r.
In total Disagreement.
I disagree with you distortedolskool, i think that you are live in the past with problems that you had out of the mounts, found a cheap solution, and knew how to use a dial caliper, I totally disagree and discredit you on your research and reliability in saying that you can make a motor mount correctly based on saftey and reliability, and test the stress level your custom mounts can take. That's why a racing motor mounts are not mean for you daily drivers in the 1st place. That's why i bought the 75A Polyureathane hardness mounts anyway.
However if no one will believe me, i wrote them an e-mail, and will post their response on here asap.
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
