Im really geeting fed up w/ keys acura
ok, let me ask everyone a question, i took my car in for a replacement cd unit and while i was there i asked if they could fix the rattle in the moonroof and readjust my headlights [the right is aiming a bit down]. i get my car back and everything was fine but i turn on my headlights and the right is still down. Let me just clarify that these people at Keys like to sugar coat everything so they get a high customer satisfaction rate, and it gets very irritating. So i just got to work and i called the agent who delt with me and told him my delima. He stated that the HID system in the car is self adjusting and there is nothing they can do to realign it. I straight up told the cat that this was bullshit, so he told me to come in friday and he'd help work out the problem..... now for you guys, can i adjust the lights or is this "self adjusting system" just a piece of shit?
"I DON'T KNOW" is something they need to practice saying
Keyes has also been pleasant and nice to me, but wouldn’t fix my lazy seatbelt retractor – among other things.
Please see the following (the headlights are adjustable). I really dislike people who can’t or refuse to add the following phrase: “I don’t know … but I’ll see if I can find out.”
Helms (2001 CL/CLS factory service manual) -- page 22-114:
Headlight Adjustment
Before adjusting the headlights:
* Park the vehicle on a level surface.
* Make sure the tire pressures are correct.
* The driver or someone who weights [weighs] the same should sit in the driver’s seat.
1. Clean the outer lens so that you can see the center of the headlights.
2. Park the vehicle in front of a wall or a screen. (EricL note: horizontal distance is shown as 25 feet from center of lens assembly to wall or screen.)
3. Open the hood.
4 Turn the low beams on.
5. Determine if the headlights are aimed properly.
Vertical adjustment:
Measure the height of the headlights (A). The lights should reflect 52mm (2.1 in) below (B) headlight height.
Horizontal adjustment:
The width of the refracting points C should be the same as the width of the headlight central points D and E
EricL note: A, B, C, D, and E are all shown in a pictorial diagram in the Helms. Look, the suckers should just do the adjustment for you. As best as I can tell the width of the lights as shown on the wall (or screen) should be about as wide as the center of your HID bulbs. (Haven’t done the adjustment on this car, so all’s I can do is pass along some info and hope it’s in the ballpark.)
6. If necessary, adjust the headlights to local requirements by turning the horizontal adjuster (A) and the vertical adjuster (B). It would be nice if someone could scan the image on page 22-115 for you. Being a bit lazy and tired at the moment, I haven’t looked in the engine compartment to identify the “adjusters”.
Perhaps this will help a little, and someone else will finish off with the final details for you.
3. Open the hood.
Re: Im really geeting fed up w/ keys acura
Got a Job!
thats BS...
If you pop your hood, you can adjust the headlight height. Chek out this thread...
http://www.acura-cl.com/forums/showt...threadid=50672
It's fairly easy, as it should only take a few minutes to do. Make sure to mark your spots so you kno where the ligths shown originally. Also, adjusting the lights just by about 1-1.5" does a HUGE difference. The entire time I've had this car, I've felt that the headlights were shown wayyyyyyyyyyyy too low. I mean shit, most people I kno have their headlights shining atleast a hundred feet in front of em. Mine were just shining like 40-50 feet in front of me. So I adjusted them and now I can see the whole road; it's GREAT!
Originally posted by Dem1K
thats BS...
thats BS...
Got a Job!
Yea I know...
I used that thread at a template and its pretty self explanatory. Just follow the directions. When you pop the hood you'll see something written in the plastic like "U <-> D" and basically if you are facing the cabin...you turn in the direction of the U to turn it up, and in the direction of D for making it go down. I didn't get to use the pictures either. It's very simple. All you need is a philips screwdriver and a flashlight couldn't hurt. Also a pen or something to mark on the wall where your headilghts beam at.
Yea I know...
Yea I know...
The last note about using a 10mm wrench might be worth noting (the Helms shows the teeth, but the picture looked "funny" using a small philips to "mesh" with the gear teeth (I guess it depends on what philips you have...)
nanos
11-12-2015 08:41 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
ahsm
09-09-2015 08:35 AM
asahrts
09-04-2015 05:55 PM
