Icebox question
Old Sep 7, 2003 | 09:02 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
Icebox question
for those who installed it yourself, do I need any of the screws from the stock intake and the stock beam that goes up against the fender wall? I think I lost them all already. If so then I'll go to acura and buy replacements.
Old Sep 7, 2003 | 09:10 PM
bullaculla's Avatar
I dont think so. I think you are supposed to remove that beam anyway. Check CT website, their instructions are pretty good.
Old Sep 7, 2003 | 09:11 PM
bullaculla's Avatar
http://www.comptechusa.com/instructions/ins110.pdf
Old Sep 7, 2003 | 09:12 PM
6spdmanual's Avatar
You don't need the stock beam. The box will occupy the space.
Old Sep 7, 2003 | 09:26 PM
civic4982's Avatar
you guys are sure? b/c the pictures show that there's still some small beam there it looks like holding onto the right side of the bottome part of the box.
Old Sep 7, 2003 | 09:29 PM
civic4982's Avatar
anything's to look out for o install guys? my resnoator is already out so it should be a mcuh shorter endeavor to install the icebox.
btw, do you guys know what I mean by the beam? it's this small metal piece that bolts right up to the side of the car. on the Injen you remove that piece to bolt the intake's side screw hole to the body so it doesn't wobble and move.
Old Sep 7, 2003 | 09:36 PM
bullaculla's Avatar
that piece comes out, and you use the hole to bolt in the box.
Old Sep 7, 2003 | 09:37 PM
civic4982's Avatar
ahh... thanks bullaculla... what about screws and nuts and bolts and stuff...
I'm stupid and lost them all somewhere.
Old Sep 7, 2003 | 09:39 PM
bullaculla's Avatar
nope.
Old Sep 7, 2003 | 09:41 PM
civic4982's Avatar
ok last question... w/ a dremel tool and resonator removed how long should it take me to install? I estimate 45 minutes to an hour considering all my tubing is already out and only 1 screw is holding my stock airbox in place.
Old Sep 7, 2003 | 09:43 PM
civic4982's Avatar
I can't wait to get it on... hopefully it's better than the injen I had. I just wanted it b/c I want everything to look stock in the engine bay...
looks like a short ram with tubing going to it... personally I think it's a ripoff for $250 but oh well...
bullaculla's Avatar
heres a tip, your bellows might rub against that little orange plug. I pulled the plug off the bracket, removed the bracket and bent it upward 180 degrees, and replaced the plug so it floats above the bellow.
here are some pics.
Old Sep 7, 2003 | 09:44 PM
bullaculla's Avatar
oly took me an hour including the removal of the stock airbox.
Old Sep 7, 2003 | 09:50 PM
civic4982's Avatar
I like the look of the grounding kit... pretty wires
if I had money to burn I'd make my own.
thanks for all the help bullculla.
Old Sep 7, 2003 | 10:02 PM
bullaculla's Avatar
I have more time than money.
and i'm not saying that i'm rich, I just have no time at all.
thats why everything I installed, including the headers, were done at night.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
navtool.com
Sep 25, 2015 05:15 PM
