IAT - Pre/Post Thermoblock
#241
That's Racist
Does anyone know of any good sources in So Cal that would be able to install this mod for me? I don't trust myself to do it =/.
Real interested in this mod.
#242
Lead Footed
Originally Posted by darrinb
mine should be arriving any day now
So did you get? Is it installed already . . . that's it isn't it . . . you got it and are burning up the streets with all that new found HP.
Ruf
#244
Installed. Had to pick up a torque wrench that I have been putting off buying anyway, but worth the cost totally. After thoughts: simple straight forward installation, but tricky on some points. The back to back bolt trick didn't work as easily as described. You really have to tighten those guys back to back to work. Also If you feel like you have torqed the bolt the right amount and the torque wrench isn't "clicking," don't troque anymore! I felt like I was borderline stripping some of the bolts when tightening them and the troque wrench didn't give. I actually broke off one of the 10mm bolts for the top aluminum cover by trusting the troque wrench. I knew when I should have stoped but waited for the "click...." instead i heard "snap." Easy fix though. Took me about four hours buy myself. I've never done any internal motor work...
Feelings on the mod: didn't feel too much of a difference in terms of power, but the intake manifold was much cooler. I did a 90 MPH run for about 5 mins from a friends house just now and I popped the hood and felt just a warm, not blazing hot like normal, intake manifold. I will definatly be checking my fluids after a week!
#245
I'm Interested... But i've no experience taking a engine apart lol ... Any recommendations to who i can take it for installation in S Florida ??, I've no problem paying but it has to be done correct.
#249
///M POWER
1 Post
installed today:
its been in the 30's latley but it got up to 48 today, even though it was a bit warmer i never have felt my car pull this hard, even after going wot numerous times on the way home when i got home and popped the hood the tb and intake werent even warm
mod is def worth the 100 dollars, great cheap mod to pick uo
#250
Smitty's Moral Police
I was all for this mod before I read about the burning oil/coolant issues. I'm here in the Arizona desert, so I'm not so sure anymore. I'm especially worried about what this would mean for warranty since in theory my coolant/oil levels could get low..any opinions/advices? How often would I need to top off the oil/coolant? (How much burn are we talking about?)
#252
I did not think there where any issues, as stated on there website...
"What are the negative side effects of running with ThermoBlok spacers?
None. Seriously. Outlaw Engineering does not know of any drawbacks to the use of properly installed ThermoBlok spacers. In addition to power increases, we have received reports of better gas mileage, better sounding induction noise, and longer life of underhood components such as hoses do to reduced temperature to name a few. "
Anyone ????
#253
#254
Resident Troll.
1 Post
Think of this as a perk of modding your car. Im pretty sure that all the guys with SCs and turbos are constantally under their hoods to make sure they have enough coolant and oil.
#255
Anyone ????
Anyone ????
While is always a good ideal to keep an eye on the oil and coolant levels, the installation of these spacers do not increase the consumption of either oil or coolant.
#256
Lead Footed
Okay, would one of the elite motorheads care to comment why there would be an issue with coolant or oil loss/usage with this mod?
Not having seen the part or having installed one I can't imagine how this would be possible. I've put spacer type mods on many of cars and never heard of this side effect.
The only thing that comes to mind as a possiblity is that of not using the cooling hoses I've heard that some don't end up using.
Allmotor? Scalbert? Smitty? Others . . . care to chime in?
Ruf
Ruf
#257
Boomer SOONER
the theory is because the heat is now not being absorbed by the intake manafold or the TB, the engine block itself is having to take all the heat and with not having as much surface area to radiate out of the engine - it could run hotter...though I cant imagine it being much more, and like most people have said, if the fluids are slightly off - just add some
#258
Resident Troll.
1 Post
Since I have had the spacers in for a few weeks now I did notice an increase in the oil use and have had to top up my coolant once. However, the temp outside has been quite cold so it should be interesting to see how everything is in the summer.
#259
Ruf
Ruf
see the IM helping much with heat soak.
The coolant/oil differences are subjective. There is no reason for coolant to drop, and I don't quite understand oil consumption. I should check inside my manifold to see if it is sucking up more oil (easy to check... just open the top cover).
Just my $0.02, but don't immediately assume oil/coolant loss just based on some posts somewhere!
D-Rob
62
01-05-2016 11:44 AM
