i know this is wrong but........... realy need some help from a computer expert
i know this is the wrong forum but i got bellsouth adsl modem, itis running trhough te usb port on my sony laptop running windows 98 1st edtion, when i install all the software for the alcatel usb modem an sign on from the instaltion wizard it works perfect, but when i try to start it from the shortcuts or the network folder, it says that the"the computer i a dailing to is not responding"
i spent 4 hours on the phne with custmer service tech supprt, and we uninstalled the software three times wth the sae result.
my next step is to reformatthe hard drive drive and reload windows and all ohther programs, bellsouth ran numerous test and theproblem is def in the laptop please some one help me out
2001 acura cl type-s
comming soon
2000 accord v6 sedan
1997 4runner
1992 camaro
1993 volvo 850
"THE GREATEST TRICK THE DEVIL EVER PULLED, WAS CONVINCING THE WORLD HE DIDN'T EXIST"
comming soon
1997 4runner
1992 camaro
1993 volvo 850
Check to see if the USB port is active on the laptop. I have had that problem before many times with notebooks. Look in the BIOS to see or else plus in any other USB device to see if it works. Ill check back later to see if that helped ya.
2001 Silver 3.2 CL-P
Tints, piaa road lamps, hyper white all around, custom eyebrows, tl-s cup holders, Acura-CL.com stickers, Xplod 10" sub and AMP, cleared out headlights, custom grill
Reformatting should be the last resort. also example of why NOT to get a vaio.
okay about your problem.
First make sure in th bios usb is enabled. Should be by default. Also check to make sure in the bios if it asks plug and play os check yes.
Next if both features are enabled, go to sony's site download a bios update for your laptop and flash your bios. Then, double check the settings in your bios and see if win98 recognizes they usb device. if it does not work go buy or borrow any kind of usb device, (mouse scanner,camera) for instance and test it w/ your usb port. if it does work then you might have a problem w/ your usb modem. I really couldn't understand if you where saying it signs on fine and gives u a valid connection during the inital setup or if the setup completed successfully. Also are you using winpoet for your dsl?
Oh, and while your at the sony site, see if they have a hardware diagnostic software where it runs a test on your hardware. usually a small program that 'll fit on disk which runs in dos.
if you still have problems IM me or email me during the week.
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter w/ J&J RAP CAI. Polarg m-6.
Comptech Headers,Springs,Sways, Eurolite Xenon Crystal high beams.Polarg m6
gtech 0-60 6.03 w/ 438 pound load. preheader.
CL-S
Try to eliminate as many possiblities as possible before calling the tech support guys.
I think you could have a bad dsl modem. but we'll see.
CL-S
CL-S
USB sucks. Its slow, buggy, and a resource hog. Its nothing but trouble. Get an Ethernet DSL modem and an Ethernet card for your computer. To make life even better and eliminate the PPPoE dialer from your computer, get a router like the Netgear RP114 that handles it for you. Then you just need a standard computer (any OS) with a standard (non kludged) TCP/IP stack.
2001 Silver 3.2CL Type S
Spoiler, Navi, Cupholder 2.0, 35% tint all around
Charter member of the Scratched Rim Club
4drviper
Apr 23, 2025 07:13 PM
AcuraKidd
Sep 25, 2015 11:18 PM
