I dont think my aculater is opening / working?
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I was watching it as soopa said and nothing opened at 3800 RPM's. The actullator is directly in the middle behind the engin, is it real noticible when it opens?
Does this mean i am driving a CL-P with a Type-S badge, I feel like such a rice boy!
It's pretty obvious, but I don't see how you can check it by yourself unless you tie something on it like a small twig or something. Were you watching it while someone else revved the car or were you by yourself??
B A N N E D
My moms was reving slowly till 4000 rpms.
I told her to tell me when it hit 3600 and i watched it till 4200, the sound of the engine changed alot when it hit around 4 k rpms, but i didnt see the aculator open or move?
<font face="Verdana, Arial" size="2">Originally posted by StonedCL:
I told her to tell me when it hit 3600 and i watched it till 4200, the sound of the engine changed alot when it hit around 4 k rpms, but i didnt see the aculator open or move?</font>
B A N N E D
<font face="Verdana, Arial" size="2">Originally posted by Rod:
Don't do it slowly, I think you need to get the RPMs up quickly.
</font>
</font>
You gotta step on it for the aculator to open.
My moms was doing it slow..
??</font>
??</font>
okay...
first, you don't have to do it slowly. It should happen **around** 3800rpms. Mine doesn't happen until 4000rpms exactly. Try revving it to at least 5000rpms before you determine if it's not functioning correctly.
second, Ash...
they're talkin' about the IMRC module that controls the secondary intake on the CL-S engine. If you do a search on IMRC you'll find plenty of info about it. Some member's IMRC's have broken (even twice... poor droid )
second, Ash...
The Creator
It should open at 3800 no matter how fast you depress the pedal.
I have seen it open while taking like 30 seconds to slowly rev to 3800 rpm... or while flooring it.
Stoned, if you didnt see shit happen... its likely that it isnt working. Take it into Park Ave Acura and have them check her out.
2001 Acura 3.2 CL Type-S
San Marino Red (Navigation)
PIAA 19173 Ion Yellow Fog Lights
Aftermarket Black Wood Trim Kit
Valentine 1
Valentine 1
B A N N E D
<font face="Verdana, Arial" size="2">Originally posted by soopa:
</font>
</font>
This seems to be a big prob on the type-s..
So if the actulator dont work then our car is a CL-P..RIGHT?
I'm gonna try it again today, i think im looking at the right thing.
its in the back in the middle of the engine..
STi
Try taking the top plastic cover of the engine you will see it better. If you take the cover out, you will see a small pulley like in the side of the intake manifold this thing connect with cable thru the actuator motor. I checked mine last week and it works, and you can really see the small pulley turn...
1990Si
2001CL-S
1990Si
2001CL-S
Stoned- Just stop by and we'll check it. Don't want you running into some old lady while you are checking for secondary throttle movement
Wayne Gruen
Service Manager
Park Ave Acura
2002 TL-S Black on Black
Factory Body Kit, Factory Spoiler, Comptech Springs, Comptech Sways, Comptech Headers, Comptech Exhaust, Xephyr CAI
Tuning by Jens
Wayne Gruen
Service Manager
Park Ave Acura
Tuning by Jens
B A N N E D
<font face="Verdana, Arial" size="2">Originally posted by wayneg:
</font>
</font>
WOW im a bad speller..
The Creator
its in the back in the middle of the engine..</font>
well... your at least looking in the right area.
it moves enough that you should definately notice if it DOES move.
Valentine 1
The Creator
and dont forget the audible clicking noise it makes when it moves.
Valentine 1
Valentine 1
B A N N E D
yes... youre looking at the right thing.
</font>
</font>
Thanks for all the help Soopa, so i dont think it is working, Im gonna take it to park ave acura to look at!
So if the actulater is not working , that means i am only producing 225 HP.
B A N N E D
<font face="Verdana, Arial" size="2">Originally posted by JRock:
Well you're a CL-P with domed pistons.
</font>
</font>
Gonnna get the actulater fixed and get my revenge!!!
So if the actulater is not working , that means i am only producing 225 HP.</font>
If the actuator is not working you are most likely producing ~225HP at the crank if not less The second stage butterfly not opening is pretty useless and is hampering performance, intake velocity, and backpressure a bit by not opening when your car can use it the most...
Chris
2001 Nighthawk Black CLS Type S - Xephyr Performance CAI, PIAA 19173(Yellow) Road Lamp Upgrades, Full Wood Trim, Spoiler, 1/4 Mile in 14.424@97.23 MPH Atco Raceway Best GTECH Sprint 5.55with Poobah watching Xephyr Performance Intakes
B A N N E D
<font face="Verdana, Arial" size="2">Originally posted by Xephyr2K:
Chris
</font>
Chris
</font>
So if i am driving my car HARD and the actulater is not opening , will it harm the enginE??
Thanks Chriss..
P.S. If u need any employees for your company..IM RIGHT HERE..
Thanks Chriss..
P.S. If u need any employees for your company..IM RIGHT HERE..</font>
Thanks Chriss..
If your IMRC is not functioning properly it is mostly a performance issue. The way it works is somewhat similar to the way 4 Barrel Carbeurators work, where two barrels would run until you hit the gas hard and popped open the other two barrels. Such that with our cars (Type S), under normal driving only one butterfly will open as the car will shift prior to hitting enough RPM to open the second butterfly. However, if you get on th gas hard the dual stage induction opens one butterfly first until ~3800-4000 RPM, in the meanwhile it has a pressurizing effect within the mainfold so when the second butterfly opens it adds a psuedo supercharging effect by introducing more air volume. There will be no harm to your car if it not opening as the pressure variant is minimal (even though it helps a bit). The computer (MAP/ECU/PFM)constantly maintain metrics on your intake, O2, exhaust etc ... etc.. etc... so you shouldnt be doing any damage. Hope that helped.
Chris
B A N N E D
StonedCL:
Chris
</font>
StonedCL:
Chris
</font>
cycdaniel
12-17-2019 10:58 AM
