Hyper Ground Wire - Revisited
Old Jun 11, 2003 | 03:28 PM
CLS2001_97124's Avatar
Revving at 9K...
Hi,
I know that this topic have been brought up before, but everytime when I try to use the search function, I get crap for result. (any advise for using that properly?)
So anyway, I was reading the lastest Import Tuner, they had a 96 Nissan 240 that they were dynoing, and one of the first mods was the Hyper Ground Wires, and it showed decend gains for the money, and I knew that you guys had talked about this before, I was just wondering what was the final conclusion members here have came up with. Is it worth it??
Here is the link.
http://sunautomobile.com/hypergroundsystem/
Thanks!!
Old Jun 11, 2003 | 06:46 PM
mattg's Avatar
i did my own home made version w/ an optima battery and streetwires connectors.
i'll have to show it to you.
Old Jun 11, 2003 | 06:52 PM
PiMpiN wHITe Cl-S's Avatar
i was thinkin the same..that is to use those type of wires..show us some pics!!
Old Jun 11, 2003 | 10:47 PM
Jens H.'s Avatar
retired
A roll of wire about 8 or 10 gauge a few wire connectors and you can do this yourself .
Jens
Old Jun 11, 2003 | 11:02 PM
lou_RENAMED's Avatar
hold off Im trying to get insanemine from the 350Z to make us a custom kit only for the CL-S. He said he is looking into it
Old Jun 11, 2003 | 11:22 PM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
hmm...I'm interested in hearing more about this stuff.
Old Jun 12, 2003 | 01:13 PM
jucee187's Avatar
PACDAT
didnt someone say before that the ground wires will do NOTHING for our carS?.. absolute zilch zip nothing..
And how would you find the right points ?? to connect the wireS?
Old Jun 12, 2003 | 02:18 PM
swclown's Avatar
4-8-15-16-23-42
i've read a couple of articles about this and they all go in saying how can this thing do ANYTHING, but in the end they're always like, "Man, were we surprised!". It doesn't seem as though it would do anything, but there were def dyno'd results that showed improvement.
it comes with suggested places to ground at but once that's done the manufacture suggests experimenting with other spots to get the most out of it.
2 or 3 extr hp --cost is like $60 bucks
Old Jun 12, 2003 | 02:31 PM
Revving at 9K...
well, I was hoping that the people who thought it wouldn't do anything has any data that could backup their side of the argument. Because between the website(for what it's worth) and the results from Import Tuner (same story here), I would almost think that it does improve the overall performance of our engine some what. I might try it out. Maybe the home made version. Now I just got to figure out exactly what wires I need to replace and where best to ground it to.
Old Jun 12, 2003 | 02:41 PM
mattg's Avatar
the grounds go from the battery negative to the engine, transmission, chassis and alternator. i think thats the idea?
Old Jun 12, 2003 | 02:58 PM
Revving at 9K...
Hum, so it's basically just a direct replacement? I figure they give you new mounting spots for a better ground.
I for sure will have to check out yours next time we meet.
Old Jun 12, 2003 | 03:13 PM
juniorbean's Avatar
LOL... I just skimmed a 20 page topic on my350z about that. Seems like those owners notice a smoother revs after 4k as well as a smoother idle. Not sure if it works on our cars.... but if it does... insanemine will definitely figure it out!
Old Jun 12, 2003 | 03:20 PM
LegendC's Avatar
The Acura Granddaddy
Is this all in peoples heads or do you really think there is benefit to this....can't dynos be off 2-5hp just based on the temp difference in the time to install this?
Old Jun 12, 2003 | 03:54 PM
typeR's Avatar
better data flow to the ECU ...and the way our ECU is...ill bet there are good gains to be had
Old Jun 12, 2003 | 04:08 PM
zigzagzig's Avatar
What is the basis of this mod? As in, what is it? What does it involve?
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I still do not understand what has the grounding to do with making more power? better ignition? what is the theory here?
It is seems just a kind of scam to me.
Old Jun 12, 2003 | 04:13 PM
typeR's Avatar
better smoother data flow to the ECU is my understanding ...if i were guessing that any sever breaks in the data stream would send the ECU straight into closed loop mode
Old Jun 12, 2003 | 04:25 PM
Happy CL-S Pilot
all sensor feeds digital signals to the ECU nosie on the signal does not affect the operation of the ECU.
Old Jun 12, 2003 | 11:44 PM
Revving at 9K...
I think it has more to do with improving the ignition system in our cars. Maybe on the same line as better plugs and spark plug wires I think....
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
ripit
Sep 26, 2015 06:19 PM
