How should "summer" rims and tires be stored for the winter?
I'm getting ready to say goodbye to the Superleggeras for the winter and was wondering what is the best way to store rims/tires in a garage over the winter?
Originally Posted by ferizzo
No need to take the air out right? I need to store mine away in a couple weeks as well!
i usually dont. they stay pretty inflated during the winter. im putting mine away this weekend also i think and this is how i always do it, the bags work fine. just make sure there are no leaks where ever u are storing them.
now is the chance to inspect, clean and seal wheels / tires.
wheels: .inspect for wheel/valve stem damage. scrub clean all metal surfaces with heavy
duty detergent.
.scrub unfinished aluminum surfaces with stainless steel wool to remove all aluminum
oxidation,corrosion, embbed dirt, road tar etc.
.apply (3) coats of liquid glass polymer polish to all painted/unpainted metal surfaces
tires : .inflate to 80% max inflation as listed on tire sidewall and mark all tires as to location prior to
removal from vehicle
.clean all surfaces with heavy duty detergent including tread and inspect all surfaces for
damage imbedded objects, bulges, ply telegraphing , etc.
. coat all surfaces with rubber /vinyl restorer -(2) coats
. bag and stack horizontal in dry area
duty detergent.
duty detergent.
duty detergent.
wow......
still a Masshole
Damn, I was thinking some soap and water and maybe a little zaino!
duty detergent.
duty detergent.
If He Dies...He Dies
Originally Posted by Shawn S
Here's what I do.......
I built a little shelf over the back door to my garage.
That way they're UP and out of the way.
Shawn S
Shawn S
u play music in your garage? Must be nice.
Doin' da crack shuffle
Here's what I do........
Clean they very good.
Zaino the metal and treat the rubber.
Decrease air pressure to 15psi.
Put in trach bags
Stack horizontally on top of each other w/ cardboard in between.
Put in trach bags
Boomer SOONER
Put in trach bags
Put in trach bags
damn anal...haha Just kidding, that sounds fool proof
I agree.
Get a couple 2x4 pieces of scrap lumber and put them on the garage floor. Then just stack the tires/wheels horizontally after cleaning and dressing with your favorite products. I keep the tires in plastic bags and set the pressure at 35-40 psi.
I read somewhere that it is not good to stack the tires on bare concrete and that they should be stored horizontally to prevent flat spotting. But the prime reason for storing them horizontally is to keep them from rolling out of the garage!!!
Yea, I hooked up an ancient Sony 110 watt per channel receiver I had lying around and a set of half decent speakers.
It’s running off a 5-CD changer I got at Best Buy for 49 bucks.
It sounds much better then I thought it would.
I also have a 27” TV out there too so I can watch a race or football game while doing the ZAINO thing.
nuldabz
09-03-2015 05:49 PM
